Soft top release from lock hinges
Gus
Ontario GTA, Canada
wrangler 2018 JLU Rubicon
today I installed my new premium soft top.
after installation, I am having issues release both front hinges to fold the top back.
When both are hooked and tightened, it’s easy to release one side, but the second side won’t release easily unless I hold the top down hard, and it doesn’t release easily at all.
Has anyone experienced that issue?
Does it get any easier with time, as the top stretches a bit or something or am I missing something??
Feedback appreciated.
k.daddy
Eric
Bay Area, CA
2018 Grand Cherokee SRT, 2019 Wrangler Moab
I’m having the same issues. Soft top went on yesterday took me 5 min to get the 2 hooks off the latch. What am I doing wrong ? Appreciate any insight. Thanks
eck
Apex NC
2018 JLU MOAB HellaYella
If you pull the latch handle all the way down, it should cause the hook to pivot and completely release. It's kinda backwards from what you might expect.
k.daddy
Eric
Bay Area, CA
Thanks for the advice. I went out and tried. Both latches don’t disengage at the same without me really working on it. Either side, individually open no problem. I was thinking since the top is on only 2 days maybe it needs more time to stretch but the latches close very easily.
Gus
Gus
Ontario GTA, Canada
Mine gets resolved when I release the hatch quickly, but its only on one side. so if the other side is held tight it gets released faster.
Try holding the top down with once hand and release the hatch fast
hope that helps.
robaw
Rob
Iowa
Mine did the same thing for about the first week it was on, just needed to stretch. Otherwise just push forward on the front bar (the one on top of the windshield) and the second latch should pop out.
thecritter
Rusty
East Texas
2018 Crystal Granite JlU Rubicon
Grab it in the middle between the latches there is a flat spot to pull down on makes it much easier on a newly installed top to unlatch.
