2024 structural changes
TexasJeeper
Jeremy
2024 Rubi 392 on order
So what’s everyone’s guess on the side impact changes for 2024. I thought about starting to order some parts for my upcoming order and got to thinking about rock rails. Only a few places I can think of to add structural strength and one of them is in the floor pan area which might affect rock rail design. Then again maybe I’m a dunce and this is a non issue.
The other area I guess could be in between the set of doors on the 4 door. I kinda doubt they would change the doors themselves as that would probably make them a bit heavier. Anyways, what are your thoughts.
yokramer
A Land of Petty Tyrants
Snark Incarnate
I mean you are ordering parts for a vehicle you havent even seen yet and is still just a theory. So fuck it buy whatever cause who knows.
sentience
Maryland
2023 Lexus GX 460, 2010 Lexus IS 350C
bureaucrat@gov
In both the 2019 and 2022 IIHS barrier tests, the Jeep Wrangler tipped over in rather spectacular fashion. This was an issue the JKs didn’t have.
If there were any structural changes, I would guess this would be a pretty good starting point.
TexasJeeper
Jeremy
Thank you for the great insight. I haven’t bought anything yet, just looking at options and starting wondering about it.
There are a few things that would probably be pretty safe to buy even during this refresh. Maybe floor mats, winch, external lights, locking lug nuts, etc.
Spank
Isn't this why they added that goofy metal plate near the pinch seam on the passenger side? I think the front axle was separating at the FAD, collapsing it behind and inwards, which was partially to blame for the Jeep rolling on impacts such as these.
snowbrdrfreak
Andrew
‘23 Wrangler Unlimited Willys Sport
Looks like the additional weight of the spare put the 2022 off-balance.
Reinen
2021 Jeep Wrangler JL Rubicon
This comparison is interesting. Was there a tire change between 2015 and 22? Seems that both deflected to the side with equal force, but the tires skidded sideways in 2015 whereas in 2022 the tires had more lateral traction and diverted that sideways energy into a roll instead of a skid.
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
The only issue I see is IF there is a change that affects an aftermarket part install, you could be SOL if you order not knowing and pass the return window…
Jtclayton612
Memphis, Tn
2020 JLU Sport S
I mean it’s possible I seem to remember a slight change on 2021 MY meant that some skid plates didn’t bolt up correctly
LKG
Larry
Boise, ID
23 JLUR Manual, Gen 2 Cummins, 22 Sport Altitude Manual R.I.P
So the roll over stuff is a major bummer but what doesn't get mentioned is how well the passenger compartment (I forget the correct terminology) held up. Glass half full here, haha. It will be interesting to see if the little hangy downy thingy helps.
RanchoShocks
CA
www.gorancho.com
2013 JKU
subed :)
When we looked it over at EJS, nothing really popped for one of our engineers.. but that was just a quick look.
I mean there were some changes we noticed like on the passenger side and the "crash bar" or whatever it is.. but it looked like control arm mounted to same mounts.
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
Buy a couple of helmets and some knee pads :rock:
Micky
Virginia
2018 Jeep Wrangler Sport S
the JL collapsed.... likely due to more aluminum and other weak parts vs the steel that is in the JK.
Bleda2002
2021 JTR, 2021 Sahara 4xe
The crash test issue is that unlike other vehicles the jeep has plastic non structural fenders that are being counted in the off set. The jk hits almost completely fender and deflects off the side of the frame, the jl barely clips frame and then gets shoved sideways as it clips out of the way as well. Would be interested to see full width steel bumper but either way the passengers had no injuries and the cabin was more intact than any other vehicle in the segment.
