2024 aux kit install help please
Bullzack85
Zack
Tacoma, wa
2024 jl 2 door
I have a 2024 2 door and I'm trying to wire in the aux switches. I got everything hooked up except that orange wire in the passenger kick panel. The plugs and pinouts are different. The aux switch orange wire pin that is supposed to go into the factory plug is too big. There is an orange wire, but I feel it is too small to tap in to. What does the orange wire do? Am I missing something?
Jeep Wrangler JL 2024 aux kit install help please 20240215_160747
Jeep Wrangler JL 2024 aux kit install help please 20240215_160719
cram501
Eric
Ashburn, VA
2019 JLUS Mojito! Moab
Going from memory here from my installation on my 2019.
You should have the plastic box that acts as a bridge between the original wire from the harness and the auxiliary switches. The original wire (square one) from the harness that plugs into the little black box, the wire that goes into the harness (square one) from the auxiliary switch wire bundle, and the other orange bridge wire (long, pointy one) that goes into the other side of the black box.
See here:
The orange wire is necessary for the auxiliary buttons. If the orange wire is not connected the auxiliary buttons will not power on. If the orange wire circuit is interrupted because something isn't connected correctly, both the auxiliary buttons and stop/start won't work.
That orange wire was a pain in the ass.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The evil orange wire is the CAN communication IIRC. I had issue with the connector retaining the pin and making contact so I just hardwired it.
ecidiego
San Diego
2021 Gladiator Mojave
Weird....why would they change that? Did you depin the orange wire from the connector yet? You cannot "not use it" - it's mandatory for this install.
ecidiego
San Diego
Not sure if this will help you, but I made this awhile back when I did it - gives you a good look at the 2019 - 2023 connector.
GATORB8
CLT NC
Just to confirm, you have removed the original pin?
Bullzack85
Zack
Tacoma, wa
2024 jl 2 door
I have it all back together so I can drive around, but I was holding the lower of the two plugs in the kick panel in the picture. There is no solid orange wire in the top plug. Neither of the plugs have a black retaining clip to hold the pins in place. Neither have a red retainer on the inside of the plug to secure them that way. I've watched all the videos available but none show the new plug in the 24. The door plug was unhooked in the door net so I'm 100% positive I wasn't messing with that. I can get the female orange pin out of the plug but not the male side. There aren't any wires that are strictly orange in any of the other plugs down there that I can see.
Techflyer
Melbourne, FL
2024 Rubicon X, 2023 JT High Altitude, 1998 TJ
New member here...
Apparently, the wire harness for he 2024s is different. I, too, have run into the same issue.
Has anyone found the work-around?
Bullzack85
Zack
Tacoma, wa
2024 jl 2 door
I have not. I put a pause on it hoping for some more info to pop up. I'm tempted to take it to the dealer just to hook up that wire.
GATORB8
CLT NC
I'll try to add some data from the <24 wiring, obviously proceed to hunt at your own risk.
The accessed circuit is "LIN BUS CBC 1"
Here's the circuit:
Jeep Wrangler JL 2024 aux kit install help please 1712612097054-fe
The kit is catching it at connector XY302A where it goes forward to the IBS.
At the IBS, there are two wires, B+ and this circuit (LIN BUS CBC 1):
Jeep Wrangler JL 2024 aux kit install help please 1712612360705-27
On a Rubi, the same circuit should exist in the locker switch. Makes sense that Mopar would not use this connection so that the kit was universal regardless of trim.
Jeep Wrangler JL 2024 aux kit install help please 1712612683836-x2
Hrdcreinfantry
Rob
Wisconsin
2024 JL RHD 2013 JK RHD
Where is this wire located?
I just received this the other day from them. I'm going to call and get better confirmation from them tomorrow, but it should be the connector under the kick panel on the passenger side that you had in your initial post. bottom corner right corner of the connector that has the rotational lock on it. should still be the orange wire but I haven't spliced mine in yet. I want to confirm with them since the PDF that they sent doesn't say what color the wire is.
Rochy01
Rodrigo
Austin
Wrangler jl 2024 sport
Hello, I have a 2024 JL, I had the same issue, I was able to spliced cav40 (orange wire) , and connected to the can, I had power to the switches panel, and I have all radio configuration , I used JSCAN, but I don't have power to the components, the external lights went I press the aux button.
Jeep Wrangler JL 2024 aux kit install help please 1000024578
