mm5300
- Mike
- Jun 12, 2024
- Atlanta, GA
- 2024 JL 4xe
I think I'm more confused than I was after reading that PDF. The step 20 doesn't exactly match up with my instructions although it is near the step for the orange wire. But what 3 wires am I connecting? There's two orange wires from the add on harness, so do those splice into the orange wire in CAV13? Which side of the connector is this done on? If you are cutting the orange wire, are you using those two ends and splicing them with one of the orange wires from the add on harness? If that's the case, cutting it and then putting the ends together with harness wire, it seems like a lot of work to use a crimp, solder and heat wrap, rather than just tapping into it.This is what I received from my dealership in regards to the orange wire and where its supposed to be connected on the 24 JL
Maybe I'm not that smart, but it doesn't seem to help me understand the steps.
