JeepViking13
- Aug 7, 2021
- Northeast
- Website
- www.youtube.com
- 2022 Willys Xtreme Recon 2022 Ford Bronco
How much does the 4xe battery replacement cost?I just proved it saves money. Even with a 10 year battery replacement I'm still ahead 10k+ by the time it happens or 6k with the new tax credit.
There is no other way to get V8 power in a wrangler unless you spend 20k so saying your bronco has V8 power (still significantly less power than the 4xe and worse fuel mileage) is a moot point. As is the assumption that jeep will put the i6 in the wrangler and even if they do unless they only charge you 4k it still costs you more for worse mpgs and a gain of ~45 hp for the standard output.
Turbos btw are ~2500 bucks a pop assuming no other damage and also have a service life similar to the battery pack so that's 5k down the line in expected maintenance which also eats away at the price difference. The 4xe also has turbos but it also doesn't use them as often so the life expectancy will be longer.
Also the 2.7 Bronco is not significantly less power then the 4xe especially if you get the factory ford tune. It's still V8 power. Regardless if it's more or less.
. He also told me a story they went on a roadtrip to Sedona or something like that, and how they had to make half hour stops to charge. Mentioned the charging spots were "fun". EV's are a hassle for most people.
