2023 with 1300 miles cold start check engine light
Chris1985
2005 Patriotic Blue LJ, 2023 JLURXR Sarge Green
Vocational Rehabilitation
Good morning. This morning in CO it was a little cold around 27 degrees. I remote started my Jeep like I always do in the mornings. About 1 min after start up it turned off. I jumped in and started with push button. Everything worked and felt good. No issues other than a check engine light. I called the dealer and it will take 5 weeks before they can see it. Anyone else have this issue? I'm hoping it's a small issue and requires a quick fix. I literally just bought the vehicle last week and it already has a date with a service department. Any thoughts? Thanks.
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
A lot of MOPAR/Stellantis vehicles only allow for a certain number of remote starts without a manual start being performed. When a remote start fails due to this idiotic protocol the PCM throws a code. One of my Ram trucks did this routinely.
The code & light should reset after 3 - 5 power cycles (On/Off x 5). You could always get the code read at a local auto parts store for a minimal fee. Some stores do it for free. All you want from them is the actual code and you want them to print out the information.
I cleared the code on my Ram with a programmer I had for the truck.
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Really? Is there any information on this? Never heard of that before.
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Found it on a Ram forum a few years ago when I was looking for information on the code.
OhioJeeper
Central Ohio
6 JL's and a Gladiator
get an inexpensive code reader and read the code, write it down for future reference and reset it. Post it hear. Could be something like an minor evap system leak.
Pinky Tuscadero
Kenosha Wi
2021 Pink RHD Wrangler 2015 RHD Wrangler
Check the codes yourself as per above and if you still need to go in...
find a better dealer !
5 weeks - wow
Jeep cares possibly
Chris1985
Chris1985
I went to Auto zone. The error code is P2B95. Called dealership and jeep said along as it will stsrt in cold weather I fine to wait till November. If the CEL starts flashing tow it to the dealership....
Poordad
Marc
Santa Clarita, Ca
2013 Acura TSX, 2023 JLUR, 2025 BMW 430i
During diagnosis a technician may find DTC P2B95 (Injection Pulse Performance During Cold Start) set in the Engine Control Module (ECM). Cause This may be caused by a calibration concern setting a false DTC. Correction Reprogram the Engine Control Module (ECM).
https://www.jlwranglerforums.com/forum/threads/p2b95.98993/
