Jmanonymous
Hi I have a scheduled appointment at the dealership in Sommerset KY on the 10th to address some issues I’ve been having with the Jeep. My main issue is when the clutch is in coming to a stop or engaging to move, there’s a spindle clicking sound resembling that of marbles clacking together as I disengage or engage the clutch. 16k miles 2022 rubicon 2 door 6 speed manual. I have a host of other issues I have seen mentioned here but the sound started after being in 4 lo in mud trying to get out of my driveway I heard a loud pop then a bunch of grinding and binding. Now it seems as if a rock is stuck inside the brake system somewhere. The 4wd transfer case occasionally will be completely locked out and won’t engage at all. I’m not sure if the ball joints loosened up but that may be a culprit for some of the noises I hear. I have so many issues with this car I’m getting frustrated any suggestions are appreciated. How do I go about the warranty work, should I make a list and give it to them when I take it in? I also have a latch on the freedom top that wants to over-rotate and loosens up while driving; the insert that the latch screws into has came loose. And also my passenger side visor just flops around because the threaded insert clips that go into the metal framing of the car are inserted very loosely whereas the drivers side are snug.
