Benson86
- Ben
- Feb 19, 2026
- Clearwater, FL
- 2022 Jeep Wrangler Unlimited Eco Diesel
Hi all, hoping to get a little advice before having to have it towed the the dealer. Its a 2022 Unlimited with the 3.0 EcoDiesel, it just over 3 years old and just out of the standard warranty but still under powertrain. Its a lease, and ill be giving it back in October. Both batteries were replaced under warranty at just under 2 years, so those batteries are about a year and a half old.
The start/stop recently started not working again, so I figured the AUX battery was prob going again. I tested both batteries last weekend with a basic analog load tester and the aux battery tested bad, while the main battery tested good. The jeep was still starting ok. I planned to replace the aux battery this weekend.
But while driving today, I forgot to turn off the auto start/stop, and it decided to engage while I was at a stoplight and shut off. When I took my foot off the break it went to restart and just died, didn't even try to turn over. Tried turning it off and restarting it and nothing, just clicks. Fortunately was close to a friends house so was able to push it to their yard. Pulled the AUX battery and replaced it with a new one, and then tried to use my friends car to jump it, no luck. It turns over incredibly slowly, like one revolution every second, tries for 10 sec or so, and wont start. And after failing to start the voltage seems to drop and it says all kinds of crazy crap on the dash about various systems not working until I turn the ignition off and on again. Without the jumper cables attached it wont even try to turnover, just clicks.
This is my first time owning a new vehicle that has a dual battery start stop system like this. Is it possible the main battery is also bad even if it tested good last weekend? Is it worth taking the main battery out and getting it tested/replaced? I just hate to spend another 260 on the main battery if there's something else going on and still have to take it to the dealer anyway. Very much hoping its not a starter issue as that's not covered under the powertrain warranty. Any advice is appreciated, thanks!
