2021 vs. 2024 MPG
alpha1847
Angelo
Boston, MA
2024 Wrangler 4xe High Altitude
So, I had one of the earlier 2021 4xe's. It was a fully optioned Sahara. I traded in for a 2024 High Altitude, which is basically a fully optioned Sahara with all-terrain tires. Both had the same axle ratio with the LSD and the same size wheels and tires ('24 Sahara's have more narrow tires for some reason)
With the '21 Sahara, I would consistently get 21-22 mpg cruising just under 75 on the highway. I could have it loaded up with 4 people and cargo with 4 bikes hanging off the back and even have eSave/regen mode on.
With the '24 High Altitude, I can barely sniff 20 cruising at 65. Just completed a 750 mile road trip on I-90 from Boston to Rochester NY and back. One passenger with a little bit of luggage, cruising just under 75 the whole way. I got 16mpg overall!
While I expected a hit from the General AT's vs the Continental All-seasons, can that big of a difference possibly be explained by tires alone?
SAJN
Omaha, NE
2022 Unlimited Sahara 4XE
FWIW, I did a quick compare on the EPA site which doesn't offer any options, and the mileage is the same between the two:
Jeep Wrangler JL 2021 vs. 2024 MPG 1738615841315-65
alphawolff
california
2021 JLU
You're only going to get 16-18 MPG in a 4XE above 75 MPH. I got 14 driving cross country in my 21. Lots of time spent around 85 in Texas.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
That's brutal. My 3.6 with XR package gets better mileage.
MaskedRacerX
DT
Florida East Coast
'24 Wrangler Rubicon 4xe
We took our '24 Rubi 4xe down to Orlando on a couple of trips, averaged right around 20MPG at ~75MPH, that's post battery depletion. And that's with the steeper gears and K02s in a 285.
I was pleasantly surprised that the Rubicon didn't lose much over the '21 Sahara we had :)
Of course, that's highway travel, our standard SOP is 90% electric only use around town where we get about 1000 miles to a tank 😎
alpha1847
alpha1847
Angelo
Boston, MA
Same for me at home - almost all short trips on electric. Prob fill up once a month at most.
alpha1847
alpha1847
Angelo
Boston, MA
The battery pack and extra components weigh almost half a ton.
Still, my 2021 4xe was the same weight and I got 21-22 without trying. 16 can't be explained by tires alone. One thing I noticed, which I don't recall in my 2021, is that it won't hold 8th gear as long. Constantly downshifts and slow to upshift. Did a test in manual mode to hold in 8th and there was not any situation it couldn't maintain 73-74, even up steep hills. Have to wonder of tranny programming (no pun intended) is part of this.
GinaC
Gina
Newport, VT
2026 Willys 2.0T 2DR Hard Top in Mojito built for me!
I think I've filled my 4xe up twice since I got it at the end of August. And that was only because I took a few trips down to Montpelier because I was so excited to drive it.
Last I checked, I'm getting about 30 "mpg".
Currently winter driving up to ski is skewing me, though, so I can't report on that yet.
alpha1847
alpha1847
Angelo
Boston, MA
Again, easily got 21-22 on my 4xe Sahara. Just switching from same size all-seasons to all-terrains cannot explain this.....
sentience
Maryland
2023 Lexus GX 460, 2010 Lexus IS 350C
bureaucrat@gov
So, dumb question - are you calculating your mileage by hand or using the onboard computer estimate? Because, as others have alluded to, the 2021-2024’s aren’t that mechanically different.
My little idiot brain thinks this might be down to a calibration difference for tire or wheel size.
Scotty Scout
Michigan
2024 Wrangler
There is no possible way that the tires are making the fuel economy drop by 6 mpg, or anything even remotely close to that amount.
I think something is off with your wrangler.
alpha1847
alpha1847
Angelo
Boston, MA
In both cases, using onboard computer. Both were stock wheels. Based on the actual range I got, it was real.
alpha1847
alpha1847
Angelo
Boston, MA
I am thinking the same thing - can only imagine what the dealer response will be......
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Right, I understand. I just thought the 4xe claim to fame was some improved mpg like most hybrids. Is it only the short miles on battery power?
