2021 JLU Sahara - Creaking rear window hinge.
DogDay
Shawn
Tennessee
2021 Sahara Unlimited 2.0T
Listen to video.
I've tried wd-40 on the hinges but it didn't make the slightest difference. I'm worried the glass may crack. Any suggestions before I start loosing the hinge screws?
whitechocolate
Fl
2021 JL 80th Edition
Listen to video.
Lucas White Lighting Lithium grease, WD40 isnt a lubricant. It breaks down grease
Do you have third party hinge sleeves ?
DogDay
DogDay
Shawn
Tennessee
No sleeves that I'm aware of. I'll try white lithium on the hinges. thanks!
DogDay
DogDay
Shawn
Tennessee
The lithium doesn't seem to make a difference. Hard to know if it's getting in between the pieces though.
PTFE? Teflon spray?
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
You need something that penetrates. Silicone is good and won't dry out quickly. This stuff is useful around the house/garage/ranch, etc.
Jeep Wrangler JL 2021 JLU Sahara - Creaking rear window hinge. 20240502_111805
DogDay
DogDay
Shawn
Tennessee
Thanks, it's coated in white lithium now so this doesn't look like an option. I may have to try and remove the hinge, clean and relube it.
DogDay
DogDay
Shawn
Tennessee
Just an update:
I loosened the two screws that held the hinge to the top and the creaking has stopped. The screws are still snug and secure.
They must have been over-tightened on the assembly line or the previous owner might have had the glass replaced? Possibly could be weather related.
