2019 Moab differential
Bubz024
Rich
Nj
2019 wrangler Moab
I’m looking upgrade the gears in my Moab, I upgraded to 37s. Problem I’m having is that I don’t know my differential size I see m220, Dana etc. does anyone know which differential I have?
thanks In Advance
Bubz024
Rich
Nj
2019 wrangler Moab
The m220 is the dana 44. Is that what your spec sheet says?
Don’t have a spec sheet just looking for what size my differentials are to buy gears & do I have to a complete kit or just the 2 gears?
intentsrig
JLU Sporticon
You will need both front and rear. You may or may not need the full install kit. Depends how many miles you have on the Jeep and if the installer is able to save the bearings when taking it apart. I had to buy 1 extra bearing as it had to be pressed off. Also, don’t go past 4.88 but I do not think that anyone makes a 5.13 for a m186 anyway.
Your front should be the m186
Ahh yeah idk for sure what you have for a rear axle. You could have the m220 or the m200. Depends how you ordered the Jeep or whatever it came with. Use this with Capitol letters. Mine states I have the rear M220 under optional equipmment.
https://fcacommunity.force.com/RAM/s/equipment-listing
Bubz024
Rich
Nj
2019 wrangler Moab
Thanks brother that helped a lot!
