2018 jlu electrical nightmare
James Faughnan
Michigan
2018 Jeep Wrangler jl
I've learned through this thread lately that there are serious electrical issues with the 2018 jlu amongst other years as well. I have been chasing this electrical issue for over a month and I half at this point. It started out by just dieing and leaving my wife stranded, so I had it towed home and began my adventures or should I say nightmare! It started off with throttle positioning and pedal sensor faults. I replaced both to no avail. I did however find that the main ground from the batteries to the body where very loose. I believe I forgot to retighten them the last time I worked on it. After that I could start it but I had a dead pedal and service traction control, shifter sensor faults and throttle and pedal sensor faults. That's about the time I found this forum and learned about the green can-bus issues, so I replaced that....and nothing....uugghhh!
Next I replaced both batteries as suggested by many here. With that came the light show that I 've read so many people on this forum were experiencing. I then tested every fuse including the hv fuse array, all good. Made sure all where seated well, check. Nothing. I then tore out both batteries, battery and fuse box and found the main ground strap from the motor to the fire wall was broken, so I replaced that. Then checked and cleaned every ground i could find. Good news is no more electrical light show, bad news it is back to not starting again. It won't come off of run unless I disconnect the batteries and I have lost communication with all modules. I even bought an oscilloscope but still can't figure it out. I don't believe that the ecm has the update but I don't know if that would make a difference. Please help😬🙄. I'm down a vehicle and now have a $30,000 lawn ornament.🫤😡😠
James Faughnan
Michigan
Has anyone had issues with the white can bus next to the green one behind the glove box? I haven't replaced that one yet. Also are those the only 2 can bus blocks?
botlfed98
Brandon
NWI & Tulsa
2019 Wrangler
i feel your pain, i disconnected batteries the other day to install some accessories...reconnected batteries and now Jeep sits in the driveway with no power to the ignition switch
