TankCustomsAlex
- Alex
- Nov 12, 2018
- Houston, TX
- 2019 Jeep Wrangler Rubicon 2dr Mojito
@TTEChris I know you had the RC track bar on your jeep and installed it on this jeep. Does it wiggle?We have a @Rough Country Suspensions 2.5" kit coming with front trackbar and rear trackbar bracket that should hold us over for the time being
Here's a cool picture @TankCustomsAlex edited
No movement/wiggle on all the RC trackbars I have installed for the JL(More than 5 now). I wish I had an answer for you, but it would probably be one of those things I need to see to determine what is causing it@TTEChris I know you had the RC track bar on your jeep and installed it on this jeep. Does it wiggle?
I installed it on my jeep, and I can wiggle it quit a bit with my hand. Seems the sleeve is not strong enough or maybe not enough thread is within the sleeve. Not quite sure.
I had the RC trackbar on a JK and it felt solid/no wiggle.
That's why I went with the RC. It was super solid on the JK. I checked torque and it was fine as well.No movement/wiggle on all the RC trackbars I have installed for the JL(More than 5 now). I wish I had an answer for you, but it would probably be one of those things I need to see to determine what is causing it
Wish you were closer....
That almost looks like the clamp is loose, or the threads are worn down inside not allowing it to clamp securely?That's why I went with the RC. It was super solid on the JK. I checked torque and it was fine as well.
Here is a video of the wiggle:
I was thinking it seemed like that as well.That almost looks like the clamp is loose, or the threads are worn down inside not allowing it to clamp securely?
I would rotate the clamps around so that the open end of the adjuster and the clamps are on the same side(If that makes sense)
