pianomankd
- Kyle
- Feb 3, 2018
- Cape Cod
- Website
- youtube.com
- 2021 JL - Sting Gray
2dr tows 2000lbs 4dr- 3500lbsI think the tow rates are the same but you would have a larger cargo rate. I was just curious, what ever the reason it is your reason. Good luck with it
Is that true though this thread says the towing capacity is 3500 for the 2 door?Thank you for the good wishes.
I understand historically and currently max tow rating for 2dr is 2,000 lbs and 4dr is 3,500 lbs because of wheelbase length.
This in encouraging if really true
Keep in mind if your two door order was assigned a VIN that vehicle will be produced. I hope you gave it enough thought so you won't have any regrets when you see the beautiful two door's start to show up as you cruise down the road in your stretched out Wrangler. You may even see yours at the dealer going to some very lucky customer!I've taken a few polls, responded to a few threads and watched the site proliferate to the point of not being sure where to make this confession: I have cancelled my 70 day old all silver 2DR Rubicon order and have replaced it with an all white 4dr Rubicon order. I also want to take this opportunity to thank the hosts and members of this forum for helping me get thru the last two winters.
That what I was going by alsoIs that true though this thread says the towing capacity is 3500 for the 2 door?
https://www.jlwranglerforums.com/fo...r-weight-tow-capacity-max-payload-specs.1440/
How was your order spec’d out?For what it's worth, this is what I was told tonight by Jeep Chat on my 2DR Rubi order although I am not overly excited on the accuracy just yet as we all know it's subject to more delays.
Brittaney: I see here that all of the materials needed to start the build process have been received. The vehicle should be entering the build process very soon.
Brian: So are you showing a D or D1 status? Have two doors begun production yet?![]()
Brittaney: D1, and we have an ETA for the start date of 5/14/18![]()
Brian: I see. Any ETA on ship date?![]()
Brittaney: So sorry that was the wrong date 4/9/18 is the correct date, currently there is not ETA for a ship date as the vehicle is not yet built![]()
Brian: So the build process should be starting in 5 days?![]()
Brittaney: yes.![]()
Brian: Very good. Thank you for your time Brittaney.![]()
Brittaney: Your welcome, thank you for contacting jeep have a wonderful night![]()
