2.0 Coolant Reservoir Replacement
croppz
Zach
North Carolina
2021 JLU Rubicon 2.0T
I think I'm gonna order the Chinesium tank which has an L shaped lower connection since that will eliminate another weak point along with the T and the Y and the heater hose fitting
That tank unfortunately has failures and zero warranty (or baffles in the tank). The mishi is baffled and has a lifetime warranty against failures. Up to you obviously but the Amazon seller isn’t gonna care they sold you a bad product
Lil Ennis
Richard
Georgia (the state)
22 JL Willys
After replacing tank and connections can you put coolant back in without whatever tool is used to to refill and purge ? My tank started leaking at 43k miles, i had Jeep replace it because i wasnt sure.
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I didn’t drain the whole system. I just sucked out the coolant from the tank, did the replacement, then refilled the new tank. Drove it around and added coolant as required over the next two days.
ChewyJLU
Central Florida
2.0JLU
So I am in the process of replacing the weak parts which are bound to fail. My tank and heater hose T is on order but we came across this plastic joint also picture 1. My friend who takes care of all out vehicles and bikes had this brass fitting lying around so he swapped the plastic T with this. The plastic was brittle. Its almost the same size and fit easily.
great idea, these are available in Amazon but how would brass react to the radiator fluid overtime?
ChewyJLU
Central Florida
2.0JLU
I just ordered the elbow, going to assume at this point that the engineering on that will match up with the mishimoto tank. I know they built it to mate with their coolant tank, but we will see if it works with another tank.
I ordered the pair connectors yesterday but seller emailed me today that they cannot fulfill my order probably they ran out. do you have the link to the elbow you ordered?
ChewyJLU
Central Florida
2.0JLU
do you know diameter of that hose where that t connector is attached to?
ScotM
Scot
Southern California
Looks like they were able to ship mine.
Jeep Wrangler JL 2.0 Coolant Reservoir Replacement IMG_6495
virkdoc
Ramandeep
Chandigarh, India
Cayenne V8, BMW 330i, BMW R1200GSA, Jeep Rubicon 2022
Now I am tilting towards Mishimoto but am worried about the lower L. Where there is a joint things can fail? Maybe the seal fails or something else.
ScotM
Scot
Southern California
I ordered just the replacement elbow and T from the Amazon supplier, they sent the whole kit, including the tank. At any rate has anyone tried the elbow on the Mishimoto tank yet? I’m going to wait until I see some leakage from under my tank, before I tear the whole thing apart and try it. the elbow fits really nicely on their tank for sure.
Jeep Wrangler JL 2.0 Coolant Reservoir Replacement IMG_6549
Jeep Wrangler JL 2.0 Coolant Reservoir Replacement IMG_6547
Jeep Wrangler JL 2.0 Coolant Reservoir Replacement IMG_6548
ChewyJLU
Central Florida
2.0JLU
Wouldn't even hesitate.
Mine just arrived. Loving the build and design features of this coolant tank. The fluid level window quick check simplifies everything. 10/10 for Mishimoto.
My tank arrived about a week ago and was looking at the bottom of that tank, what was the hole for found underneath?
TrailMax
Max
Arkansas
2023 Wrangler High Altitude 4xe
The one by the lower mounting tab? That's for the overflow if your coolant system builds up too much pressure. You can see the tube coming out just under the cap, then runs through the top of the tank to the bottom as a vent. Better down than everywhere!
calbert
2000 TJ, 2005 TJ, 2018 JLU
I just installed the Mishimoto tank and baja customs T fitting a few weeks ago. So far so good.
Before
Jeep Wrangler JL 2.0 Coolant Reservoir Replacement 1780424775182-es
After
Jeep Wrangler JL 2.0 Coolant Reservoir Replacement 1780424819894-pl
