$100 gift card from work...
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
I won a $100 Visa gift card from work today.
what would be the one part that you think would be most likely to fail or get damaged when off-roading that I should put this money towards?
I'd save that $100 until something actually broke, failed, got damaged and then use it to drown your sorrows for the day.. or maybe put it towards skid plates (nice Metalcloak/ASFIR-type shit) 🍻
yokramer
Snark Incarnate
$100 goes a long way on alibaba as you know Im sure you can figure something fun out
Blues Fan 30
St. Louis
$100 will get you like 300 ducks off Amazon. You can use them to pad between you and rocks/trees/etc on the trails.
Roky
Roky
If I wanted to run 37 early next year, what would be the one part that you think would be most likely to fail or get damaged when off-roading that I should put this money towards?
I'm looking for a part in the $150 range if at all possible.
What do you think? Steering stabilizer? Track bar? Wheel spacers?
If I run 37s next year, what one part would have benefit most from?
If I can only pick one, I’d say track bar…. The oem track bar is junk, it doesn’t stand a chance with the rig on 37s…
Deleted User 38384
Not a bad idea actually! There's quite a few things on AliExpress that I see when I'm on there and I'm just like I'm not giving China $60! On the flip side the second it gets on Amazon those same things are like 200.
From a risky standpoint, it's actually a really fun idea!
Blues Fan 30
St. Louis
I forgot to mention, if you get the 300 ducks...if you're stuck in the mud just throw a couple handful under your tires and now they're recovery ducks. Get a gash in your tire and won't hold air? Stuff your tire with ducks and roll your way on home. Need to Ford a river? Tie them to your jeep and float on across. Break a bump stop? Rubber ducks. Need to protect a tree from a winch line? Rubber ducks. Want an alert for when you're too flexed out and your tire is about to rub the fender? Rubber ducks. Look I'm not telling you how to spend your $100 but anything other than 300 rubber ducks just doesn't seem like you're maximizing your money.
Deleted User 38384
Got to say, you drive home some really good points! 😍🤩
Deleted User 38384
baby oil could help you get unstuck. $100 would go along way. not freak off amounts of baby oil but a jeep full.
I only buy GHB oil!
You'll be walking around the Walmart parking lot trying to figure out where you parked your Jeep, not even realizing that you went off-roading that day and the Jeep's still on the trail!
🤪:LOL:;):like:
