Differential Covers
Fish
Darren
Southwest Michigan
2018 JLU, 2019 F150, 2023 Subaru Outback XT
Boat Sales
The Rustoleum Bedliner is the Goat, I have used it and self etching primer on the last 3 jeep bumper sets I have had and it holds up great, and its easy to touch up! I personally rock the Motobilt diff covers and they have taken some crazy hits.
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
Any recommendations and/or considerations such as durability, cooling capacity, etc?
Hard to beat AFE's diff cover...beautifully machined, fill plug, drain plug, sight window, doubles capacity to 2.2 quarts, has 2 magnets, one on the drain plug and one on the fill plug with a rod that extends down, aluminum construction with some cooling fins. Put the best gear oil in it: Redline.
Jeep Wrangler JL Differential Covers AFE diff
kah.mun.rah
Merenkahre Jr.
Duat
I think it depends on what you are going to subject the Jeep to. They both serve a different purpose. The thicker diff cover to protect and add rigidity, and at least with the NV, a diff skid that protects the pinion, I’m not hard core and probably just use poor judgement, but I wouldn’t give up either. These have been resprayed multiple times.
My dif skids look just like that and my original covers are fine. Since I already have the skids for dif protection, I put the dif cover $$ into shock tower skids.
Terrymo
Terry
2023 JLURXR 3.6 ET
I have “all the skids” available for the JLU that I’m aware of and like to say I have “skids on my skids”. I did have to modify the front next venture diff skid to add the front lower control arm skids. I wheel with a guy who rarely hits his skids while I seem to get good use out of all of them. Of couse he has 40 years of experience wheeling Jeeps and I have 3.
kah.mun.rah
Merenkahre Jr.
Duat
The primary purpose of the HD dif cover is to be thick enough to prevent the bottom lip from bending when hitting a rock. If the bottom lip is protected by a skid, the thicker lip is unnecessary overkill. If someone is able to impact the face of their dif and wants extra protection that way, hats off to them because it would take a lot of talent to hit the face of a front dif. without hitting all of your steering suspension first and the only way to hit the rear dif. face would be if you were driving through the rocks backwards. I suppose depending on the design, better heat dissipation might be one case where a HD dif cover and a skid would be used at the same time.
All of that said, needed or not, they do look cool.
virkdoc
Ramandeep
Chandigarh, India
Cayenne V8, BMW 330i, BMW R1200GSA, Jeep Rubicon 2022
I went with the Nitro brand...Aluminum....found a good deal on eBay since I think the company got sold or something. Its Australian.
kah.mun.rah
Merenkahre Jr.
Duat
@kah.mun.rah
I’m not convinced about the small amount of added capacity or cooling capability but overall rigidity seems reasonable to me.
I guess I would have to see someone with an example of a stock cover failing when a skid is used before I would invest in both.
ArmyRN
Paul
Longview, WA
1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
This is what I'm running, but in raw aluminum.
Jeep Wrangler JL Differential Covers 20250414_141533
beewil
Reno
2024 Rubicon X
24' Rubi X JLU and went with Currie Diffs (front and rear)
Jeep Wrangler JL Differential Covers 1781281735375-k5
Terrymo
Terry
2023 JLURXR 3.6 ET
I have no expertise and am just repeating what @chevymitchell and @grimmjeeper have said. Under load, the housing will deflect causing the gears to not mesh completely. This deflection, for people that wheel hard, is something to keep in mind as the stock cover isn't designed to do anything except seal the housing cavity. Most aftermarket covers are made thick for this reason more than the ability to take the hits.
i tend toward unnecessary overkill I suppose
kah.mun.rah
Merenkahre Jr.
Duat
The great thing about the forum is I learn something new every day. I can see the tubes on the axle housing deflecting so I have added trusses for that but I would like to know more about cast differential housing deflection if anyone has time to elaborate.
Y2KFirehawk
PA
2019 JLU Sport S
I wouldn't rely on the cover for draining the fluid though since you will never get the oil in the bottom of the dif.
With magnets and pouring some new fluid to flow through before replacing the drain plug, this is mostly mitigated. That said, I can agree with the concerns of visual inspection but your frequency to do that may vary.
