Wiring Driving Lights
Terpsmandan
Terpsmandan
Penn Yan
Nope, you have to turn that functionality on with a Taser or JScan.
It has been doing that since we got it without either. I see where I can change it the Tazer I put in three weeks ago, but haven't gone into that setting.
Terpsmandan
Terpsmandan
Penn Yan
Your fogs stay on with high beams in stock form? You have a very unique jeep then.
We have factory LED's. I thought it did it from when we got it. Maybe I turned it on accidentally with the Jscan before I removed it.
Terpsmandan
Terpsmandan
Penn Yan
As it turns out, they do go off with the high beams. My mistake. Back on topic. So can I pull the pass side headlamp and install a posi-tap on the WH/GY right high beam to trigger the relay for the driving lights?
BDinTX
Dallas, Tx
I had to google what a posi tap was... ya that will do it.
How come you're not already done with this project??? ; )
Terpsmandan
Terpsmandan
Penn Yan
Because I only picked it up two weeks ago. I still have to get the bumper installed and it’s a little cold here in WNY
Jeep Wrangler JL Wiring Driving Lights 01528F9C-E93D-4EF6-88FB-AEADD8B5018D
BDinTX
Dallas, Tx
That bad boy looks nice! Congrats!
Terpsmandan
Terpsmandan
Penn Yan
Thanks. She has a Diesel too.
Jeep Wrangler JL Wiring Driving Lights 712CBE64-8D2D-4022-9259-FA1CEF072E0E
Terpsmandan
Terpsmandan
Penn Yan
Got the Hella's installed yesterday. Stupidly easy to rig up the trigger. I went to the drivers side headlight to install the Posi tap. Not like setting up a JK and anti flicker harness to keep the relays from buzzing due to modulated voltage.
Terpsmandan
Terpsmandan
Penn Yan
Whaler27
Alex
Oregon
Saving the world :-)
If you don't happen to have any extra wire on hand you're in for a shock when you go pick some up. 12 gauge copper was $50 for a 100 ft roll... : (
Good luck!
The local auto parts stores really slap the wood to you on electrical and wiring components. I buy all that stuff from Amazon. The savings on wire may only be 50% to 70%, but on fuses, connectors, and shrink-tube bought in bulk it’s been closer to 90% savings.
On wire purchases it can save money to buy 100’ rolls of two-strand, as you’re really getting 200’ of wire, and the strands peel apart easily.
Amazon wire
BDinTX
Dallas, Tx
The local auto parts stores really slap the wood to you on electrical and wiring components. I get all that stuff from Amazon. On some things, including wire, the savings may only be 50% to 70%, but on fuses, connectors, and shrink-tube bought in bulk it’s been closer to 90% savings.
On wire purchases it can save money to 100’ rolls of two-strand, as you’re really getting 200’ of wire, and the strands peel apart easily.
Amazon wire
Good tip! I was getting it from Tractor Supply because I was already there and to be honest, they're probably priced higher on wire than an auto parts store.
Hadogenesmike
Temecula, CA
2024 JLUR
