Windshield washer pump on but no flow
Suffolklou
Lou
Richland Wa
2020 JLUR
I think that the rain-x wind shield washer fluid is great, been using it for years, 20 or so. no clogs. I love how the rain just slides off of the glass.
I always use the orange, is there a difference between the orange and green when it comes to clogging?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
I don’t know what the difference is but most of the problems I’ve seen I remember the fluid being the green version.
Martial Fartist
Christopher
Spring Hill, Florida
My pump took a dump too. Prolly rainx.
Jeep Wrangler JL Windshield washer pump on but no flow IMG_3217
How did you get to the pump? I thought I could get to it from the wheel well but can not. Did you pull the ECU and was it trickier than disconnecting the wiring and 2 bolts? Was hoping for a 10 minute fix but it may be more.
Thanks.
Terrymo
Terry
2023 JLURXR 3.6 ET
DaltonGang
Doesn't Play Well With Others
One thing that can be done: Blow air through the lines, low pressure, back into the tank. This should dislodge any crud in the lines, and whatever is clogging the pumps inlet side. Then, shove a water hose into the tank, turn up the pressure, and flush the tank of all sediment. I've done this several times, since the late 70's. Easier than taking things apart.
