No windshield washer
kipco
Indiana
2018 jeep wrangler unlimited Sahara
2018 jeep wrangler unlimited Sahara low washer light on and fluid is full no pump working.
replaced pump and level sensor and filled back up still no pump or washers.
what is my next step to look for?
Heimkehr
Pennsylvania
2021 JLU 2.0T
Disconnect the fluid lines completely and carefully run compressed air through them. You may just have a blockage that needs to be cleared. I say "completely" because you don't want to direct any such blockage to the nozzles on the hood, which might make the problem worse.
When you say no pump, does that mean there's no buzzing sound to suggest that it's working when you operate the relevant lever on the steering column? If so, recheck all of the related electrical connections, and the relevant fuse in the PDC.
kipco
kipco
Indiana
Low washer light is on as well and tank is full.
kah.mun.rah
Merenkahre Jr.
Duat
I hate to ask but which opening in your engine bay did you pour the windshield cleaner into?
