Willys 285/75 17
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Did the spare 285/75/17 fit on your stock carrier? I also have a JLUW and from what I gather its very close. Options are to pressure down and/or heat gun /press down on the plastic sport bumper where it rubs to fit it.
It did not.
It rubbed on both sides. I already had a plan to replace the stock bumpers so I wasn't too concerned.
Willys_Wonka
PA
JLUW
It did not.
Ok, so it fit (tailgate closed) but the tire just rubbed on both sides of the bumper contact point(s)? I'm thinking pressuring down to about 32# might be enough to totally clear the bumper. The other option is to heat gun it while pressing down on the bumper contacting points.
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Ok, so it fit (tailgate closed) but the tire just rubbed on both sides of the bumper contact point(s)? I'm thinking pressuring down to about 32# might be enough to totally clear the bumper. The other option is to heat gun while pressing down on the bumper contacting points.
Exactly.
Karnak
Yan
Ottawa, Canada
19 JL 3.6 Sport S - 2 door
government
I'm running 285/75 Toyo open country AT/III on stock sport S bumper on factory wheels and run 30-32 psi and it brushed slightly but could still open the tailgate just had to work at it harder a bit, well worth the rub for those tires....? I will say thought that after a few thousand km of wear, its all good now...?
CMTAZ
CMTAZ
Phoenix
2024 JLURX Anvil
I don't recall - and i sold the Wrangler a while ago, BUT I'm thinking 22 - 25 psi. I backed off enough just to clear the bumper, but wanted enough psi that if i had to use the spare it would fine to drive on (till I could get more air).
Willys_Wonka
PA
JLUW
Thanks. I might just use a Rough Country relocation bracket, only about $80. The install is straight forward. Did you re-calibrate the speedo after the 34" tires were on?
CMTAZ
CMTAZ
Phoenix
2024 JLURX Anvil
No recalibration, an unscientific test had this off less than 2 mph @ 70, therefore good enough.
Willys_Wonka
PA
JLUW
285/75R17 Toyo ATIIIs on my 2021 Willys Edition, stock Moab wheels, stock height:
No issue with rubbing on easy to moderate trails. I've since lifted the Willys to be able to tackle some more technical trails and I am having no problem on those either.
Madd, do you have black lug nut caps on and if so what size, link?
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Willys_Wonka
PA
JLUW
Nope. What you are seeing is a full set of Gorilla #96644BDX wheel locks which includes 23 locks plus the key socket - 5 lugs per wheel on the ground plus 3 locks for the spare.
I got them from Amazon.
Amazon - Gorilla Wheel Locks for Jeep JL
Very nice, but 200 bucks, ouch! I like the acorn shape, so it doesn’t show any exposed silver from the OEM rim with these new black lugs?
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Nope. No silver is showing.
When I got them, with a coupon and discount code, I got the full set for $129 and shipping was free as I have a Prime account.
Willys_Wonka
PA
JLUW
I found a set for about 150, so not too bad considering inflation. Do you know the torque specs, if not I'll research it?
JL MADDOG
Michael
Apache Junction, AZ
2021 JL 2.0L Turbo
Jeepin'
Torque is the same as your wheels with stock lugnuts... 135 ft/lbs
Fourthandlong5
Pottstown, PA
2025 Wrangler Willys
