Hi Brandon,Will any level 2 32 AMP Ev charger work? The Mopar ones are all out of stock, recommendations for chargers that work off Amazon?
I went with the Autel MaxiCharger 40AMP NEMA 14-50 with in-body holster. I think it was $440ish when I got it ($480ish after tax). Its installed outside, works really well and they are doing a good job of adding requested features all the time. Highly recommend this as it is ~$100+ cheaper than most other options.Looking at Amazon today, I'd probably get an Autel charger, $479 for a smart charger is a great deal, with prime shipping to AK.
Grizzl-e now makes a smart model you can connect an app to if thatās ur thing. Just ordered mine direct from their website. Longer wait but came in about $20 cheaper than on Amazon and they will set the Amperage DIP switch for you at the factory to match Jeepās 32A input limit. But really necessary but I figure if the Jeep doesnāt have to decide to scale down the amps well thatās just one more thing that canāt go wrong. And THAT is how you jinx yourself.Another Grizzl-E here, classic with the NEMA 6-50 plug. Had mine almost 2 years now, no problems at all. If you need a smart EVSE this one won't be the one, but if you want a simple bulletproof unit I'd definitely look at it.
the only reason to limit the charger is if your circuit can't handle the full 40A. But if its the only thing on a 50A breaker then leaving it at 40A max is correct.they will set the Amperage DIP switch for you at the factory to match Jeepās 32A input limit. But really necessary but I figure if the Jeep doesnāt have to decide to scale down the amps well thatās just one more thing that canāt go wrong.
