Which hard top removal device would you recommend?
Murphydog
Larry
Seattle
2020 X3M, 2023 JLUR XR
Jeep Wrangler JL Which hard top removal device would you recommend? 42DDFCF1-EDD0-4521-9D4F-ACA3D3A745E2
Jeep Wrangler JL Which hard top removal device would you recommend? 09F5E153-D08C-4CFB-93FD-14F45B51E0CA
Jeep Wrangler JL Which hard top removal device would you recommend? 2616BF82-95AE-410D-BC7C-10EA725DBF78
Harken Hoist installed! I have a roomy unfinished garage with a 4 foot deep shelf that hangs down along the rear and side of my garage.
The hoist was straight forward to install, though all the work over my head tired out my shoulders. The toughest part for me was knotting the ropes. I was never a Boy Scout and knots are not my thing. Thankfully my neighbor helped out.
I will shorten up the straps a bit to level out the top, and I will move the four pulleys forward an inch or so, this will allow the rear window to miss the angle iron that holds the shelf up.
The hoist itself easily lifts the top and the locking mechanism is simple and strong.
if you have the space it is a really solid solution.
2020 Rubi Diesel
Aaron
Southern IL
2020 JLURD
I’m doing this exact setup
I just did mine on Saturday based off his video. I used a bigger hoist from HF. I haven't done the back up safety wire. My top wanted to spin once it was in the air and trying to stop it from doing so was frustrating.
Murphydog
Larry
Seattle
How much was the power hoist?
Kllrbee
IL
Jeep
I use a cherry picker if friends arent around to help.
desmo2
Lake of the Ozarks
'97 TJ '97-'11. '21 billet silver JLR
I had a ceiling mounted hoist for my TJ.
I have a Lange Hoist-A-Cart Gen 2 for my JL.
Really, it depends on what your needs are.
I had a deep shop area in my garage when I had my TJ, so the hoist worked very well. I didn't opt for the motorized version, as the hand crank was easy enough and cheaper.
Now, my second garage is 20'x30' and kind of short. I didn't want a suspended hard top to hog up a bunch of space. It has a concrete floor, so a cart works well. I chose the Lange because it was cheaper than the Top Lift Pro. Vertical clearance was a concern with the Lange, but it just fit under my short ceiling. As a bonus, the Lange cart has attachments to hang the doors on. Now, once the cart is loaded I can move it around the garage to get it out of my way.
Murphydog
Larry
Seattle
I thought I found a top lift locally for under $500 and was going to snap it up, unfortunately someone beat me to it
Andrew2311
Andrew
Virginia
2018 JLU Rubicon
I am trying to decide which hard top removal device to get. I realize the portable carts are more expensive than the overhead hoists, but I am more interested in any problems with each type. I would like to know from people who actually use them how they feel about the following:
1. Overhead mounted manual hoist in the garage.
2. Overhead mounted motorized hoist in the garage.
3. Portable carts such as TopLift Pro or RollnJack.
I love my Freedom jack. It is small (mounts on a standard engine lift) and I roll it around my shop even with the top on it. The biggest advantage that I see, is that I don't have to back under it like a OH lift. I just open the doors and the back window and roll it right in, remove the screws and lift it off, and push it to where ever I want to store it. Top is on the lift in the upper Left of the pic.
entropy
Foothills of the San Gabriels
Jeep Wrangler Sport S JL 2-D
Toplift pro is worth every penny. Sometimes I take it off just for a joy ride and then get the top back on. Less than 5 minutes. I spent the longest just getting the electrical wrench out of the garage and moving the top around the house.
Of course easy for me to say it is worth every penny, since I pay $350 for it on craigslist.
Murphydog
Larry
Seattle
I thought I was going to get 1 at $450, but at the end of the day I need the floor space. If I had a bigger garage I think I would have done it
Murphydog
Larry
Seattle
Jeep Wrangler JL Which hard top removal device would you recommend? 20190624_133833
Made some adjustments today, moved the 4 pulleys forward and the rear glass now clears my over head shelves. l also adjusted the straps so the top is level when lifted. Lastly I will shorten the knots a bit, need to hoist it a touch higher so I can back all the way under it.
side note, sure is tough to disconnect the power to the hard top, not sure what I am doing wrong.
2020 Rubi Diesel
Aaron
Southern IL
2020 JLURD
I didn't know that backing under an overhead top would be difficult to some. 🤷‍♂️
I prefer the extra floor space that my OH top provides.
AVGeek99
Delano, MN
2021 JLUR, 2021 Sahara 4xe (wife's)
I have a Lange Original Power Hoist. Only $450, no brainer in my book. Hangs from the ceiling up out of the way. Someone to guide you in helps with alignment but can easily do by yourself, maybe it takes a few extra minutes to get it lined up. But I take it off in the spring and put it back on in the fall.
If you have the ceiling space in your garage (I have much more ceiling space than floor space), you can't go wrong. I highly recommend!!
