Weird engine codes and can’t find the cause.
ah-z
ah-z
Sacramento
JLRU, Twisted Customs Rock Crawler
I have a 2021 3.6 etroque motor and for some reason it’s constantly throwing U02A9, P023B, U05AA all related charge air coolant pump which is on a turbo motor but not a 3.6.
In turn my engine fan is coming on at about 170deg as well.
any help would be great
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
It’s a bad title for the fault but it is referring to the auxiliary cooling pump for the 48V battery system.
ah-z
ah-z
ah-z
Sacramento
I'm getting verified ground from the back wire on the plug at the pump, I'm also getting 12v from both the red and white wire, as well as the solid red wire. Even when the vehicle is turned off.
alphawolff
california
2021 JLU
Check for Short to voltage on the white wire. Lin bus should be about 10v, not 12
