USB port Connection
Realtor D
Darcy
Owatonna mn
2022 jeep wrangler JL Sahara high altitude
Hi all,
I just purchased a 2022 Wrangler Sahara and got a wireless charger thats in my new phone holder and it works for a couple of seconds then my screen shows that my device isnt supported. So then I get another cord and try another port and I get the same thing.....I have read old posts from 2018-2021 but I didnt find the fix.....any help would be appreciated.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Hi all,
Are you wanting to just keep your smartphone charged or do you want charging and data capability?
Rhinebeck01
Retired at 55 ..
I just want my phone to charge
@Realtor D
If you buy and use a charge only USB cable, you can plug into any USB port on the JL and you will never have any issues when charging your smartphone.
In regard to the JL's USB ports, they can be either charge only or data and charge capable.
Realtor D
Darcy
Owatonna mn
@Realtor D
If you use buy and use a charge only USB cable, you can plug into any USB port on the JL and you will never have any issues when charging your smartphone.
Thanks, I wasnt aware of a "charge only" cord.
Bobby Hank
Robert
Gulf Breeze Florida
2024 JL Wrangler Rubicon X 2D
Educator
I like that the wireless charger needs a chord... just plug the phone in, eliminate the extra contraption. Think of it as skimming weight off the rig.
Rhinebeck01
Retired at 55 ..
@Realtor D
You can use you current data/charge, USB cable on a power only USB port and then you also will have no error notices in regard to data..
Try each of your USB ports to see which are power only. Just plug your smartphone into each USB port and see.
Also, You can go into UConnect and look at available USB ports listed there. IF, not listed in UConnect that port is charge only.
IF, if your center console has USB ports on the back side, the one on the right rear is a charge only USB port.
