URGENT: NEED HELP WITH CODES
2DR OVRLND
Georgia
www.youtube.com
2021 Wrangler JLR 2.0T / 2016 Polaris Ranger 900XP
Hey y’all, was driving my rig back from the store and when it was building boost in 2nd gear it lit up like a Christmas tree and went into limp home mode. I pulled in to an empty lot and tried to shut it off and turn it on again but that didn’t fix it so I used the error code viewing feature and wrote down all the codes. My brief search on the forum was inconclusive so I decided to not tow it and just clear the codes for the moment with the tazer. What should I do?
Jeep Wrangler JL URGENT: NEED HELP WITH CODES IMG_6646
2DR OVRLND
2DR OVRLND
Georgia
www.youtube.com
Forgot to add that it drove home fine after clearing the codes but I know this is by no means a long term fix.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
How are the batteries?
elf883
steven
NY
2024 jlu willys anvil
stationary engineer
try removing the tazer see what happens
and while its out do a firmware update of the tazer then re install
to me it just sounds like a glitch
not much help with the problem sorry but this is what those codes are for/causes
P2174
Faulty Manifold Absolute Pressure (MAP) Sensor
Manifold Absolute Pressure Sensor harness is open or shorted
Manifold Absolute Pressure Sensor circuit poor electrical connection
Faulty Throttle Position (TP) Sensor
Restricted air inlet
U1428
Faulty Transmission Control Module
Transmission Control Module harness is open or shorted
Transmission Control Module circuit poor electrical connection Faulty Powertrain Control Module
C121C
Faulty Anti-Lock Brake System (ABS)
Module Faulty Powertrain Control Module
C2227
Faulty Antilock Brake System (ABS) Module
Antilock Brake System (ABS) Module harness is open or shorted
Antilock Brake System (ABS) Module circuit poor electrical connection
p2225
NOx sensor failure
Powertrain Control Module (PCM) failure
Wiring issue
2DR OVRLND
2DR OVRLND
Georgia
www.youtube.com
P2174
U1428
C121C
C2227
p2225
NOx sensor failure
Wiring issue
Thanks for the advice- I’ll try that asap. I just remembered that I was manually shifting with the auto and that stopped working for a second if that adds to it.
elf883
steven
NY
stationary engineer
try the tazer update
really sounds like a glitch - it cant be your battery /batteries already your rig is a bit to new , but who knows , mopar batteries are the worst ever
check that also bench test it/ them
sorry not much help to your issue those would be my first 2 things i would look at
MichaelT333
Delaware
2022 Willys
Throwing all those codes at one time means you can’t look at each one and try to diag each code. The odds of multiple systems and modules, failing at the exact same time or pretty much zero instead, you need to look for what can cause your jeep to throw a bunch of nonsense codes at the same time this is always usually something electrical possibly your battery a bad connection, or a loose ground or bad ground somewhere however, in the future, I would highly recommend not clearing the codes unless you can rule out nothing is wrong with the code that you’re clearing. Also, your jeep went into limp mode to protect itself by you clearing the codes and telling the jeep all is good. You could do some serious damage by forcing it to operate in normal parameters when something is wrong , but just to give you somewhere to start it’s gotta be something electrical. And going off of all the codes that itdid throw you will notice a common theme to them all is open circuit or shorted ground. You could try pulling up a wiring diagram to see at what point do all those systems come together as in I wouldn’t be a bit surprised if they all share the same ground or the same fuse, so that is where I would start figure out what do those systems have in common and where do they come together then you will find your issue. I am going with a bad ground or shorted wire coming from a fuse that they all share.
JLUR_Pete
Arizona
2020 Jeep JLUR 4-Door, 3.6 l V6 stock
I don't know what it is, and I'm not saying it is your batteries, but ...
I have replaced both batteries twice on my 2020 JLUR prompted by inexplicable electrical weirdness (like dash lights, ESS switch, gauges, A/C operation, etc.).
However I feel it is better to replace the batteries early and often, rather than get stranded out in the desert in 100+ temps.
For your 2021, based on my experience, I would not be surprised if your batteries are close to end of life. But my engine is a 3.6 and yours is a 2.0T, so that is a big difference.
Having the dealer look at it is maybe a good option...
FWIW. Good luck solving your problem.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Without understanding what these codes even mean, the only advice that can be given is misdirection. Several of these faults relate to engine torque request failures, the primary fault is the low air flow. Has your air filter collapsed?
elf883
steven
NY
stationary engineer
Did u update the firmware of tazer. Any news on the glitch ?
