Upper control arm skids? Alternative
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
I've got the Rusty's rear frame side, and they are hoss, they don't have a front though.
Do the RH's just use the CA bolt on one side? If so, I think the Barne's ones may do better even if they are thinner.
The Barnes look strong. Some simple drilling.
JP52
Walnut Creek, CA
2022 JLU Rubicon XR
I bent both of my skids the same way. I bent them back into shape and welded a few pieces of 3/16 flat bar together to make pieces that bolt to the frame so that the skids cannot bend away again. On each side there was one threaded hole in the frame from a factory skid that was removed when I installed my belly pan and another hole in the frame that I made a flag nut to fit. In the end there are 2 bolts holding the piece I made so it can't turn. Time will tell how it all holds up but it seem very strong and has survived a few hits so far. Hopefully, the pictures below make it clear.
Jeep Wrangler JL Upper control arm skids? Alternative bent skid
Jeep Wrangler JL Upper control arm skids? Alternative brace side vi
Jeep Wrangler JL Upper control arm skids? Alternative brace bottom view
Jeep Wrangler JL Upper control arm skids? Alternative bent skid off jee
Jeep Wrangler JL Upper control arm skids? Alternative parts for the brace
PropaneBender
PropaneBender
Benjamin
2020 JLUR 2.0
Yeah the rock hard just uses the one control arm bolt so it’s secured via 1 point on the chassis
PropaneBender
PropaneBender
Benjamin
2020 JLUR 2.0
That’s awesome, glad that works in your case, but unfortunately I don’t know how to fabricate metal or weld haha
PropaneBender
PropaneBender
Benjamin
2020 JLUR 2.0
Terrymo
Terry
2023 JLURXR 3.6 ET
Well I’m just quoting rock hard
I knew what you meant but some of RH4x4’s descriptions use some strange wording. Here are mine. I guess I’m not trying hard enough. Mostly slow scraping and screeching on lower skid areas rather than hard hits. The Barnes version looks like the way to go.
Jeep Wrangler JL Upper control arm skids? Alternative IMG_2411
Jeep Wrangler JL Upper control arm skids? Alternative IMG_2414
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
What is the random hole for?
Would bolting something with a button head be enough to keep it from rotating? Could almost use a botton head/recessed washer on the bottom and a T-nut on top.
PropaneBender
PropaneBender
Benjamin
2020 JLUR 2.0
What random hole
Terrymo
Terry
2023 JLURXR 3.6 ET
Creek water drip from Saturdays trail run. Or SoCal hard water spot. Maybe all the minerals and crap in our hard tap water gives me an extra layer of protection.
EDIT: after double checking , there is a hole but it’s not directly under the control arm mount so it would take maybe L shaped bracket coming off the bolt for the control arm and then you could bolt to that. I’ll just use these and switch to Barnes in the future
PropaneBender
PropaneBender
Benjamin
2020 JLUR 2.0
No it’s a hole check there website I thought it was a water spot also but the one on there website have a hole also
