Unplugging SGW Cables for Tazer Impacts Audio/Temp Control
LUKYDUK
Tim
North Texas
2019 Wrangler Rubicon
Looking for guidance / ideas.
Unplugged SGW cables to install Tazer Mini. Went through full programming and Tazer seems to be working as advertised. However, I cannot leave the SGW cables plugged into the Tazer for the "live" functionality. When I do, my center console controls (audio/temp) is completely blank/dead. As soon as I plug them back into their original location, everything works fine.
This leads me to believe it is my Jeep issue, not a Tazer issue.
Has anyone experienced this? Any advice on a solution?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
That shouldn't be happening with the Tazer plugged in, it emulates the SGW. That does happen if you leave the connectors not connected to one or the other.
LUKYDUK
LUKYDUK
Tim
North Texas
Thanks for the reply. Unfortunately, that's not the case here. Maybe it is a Tazer issue...
GATORB8
CLT NC
That would be my guess, especially if it works plugged into the SGW.
Grayhound
Michigan
Jlurd
I was wondering if 24my was the reason. A 19my should see the tazer as the sgw
LUKYDUK
LUKYDUK
Tim
North Texas
Have reached out to Z Auto. Will see what they say and post back here...
JeepFiend
Michael
Bryan, TX
2022 Wrangler Rubicon 2 Door, 2011 Ford F-150 STX
System Administrator
yep, they're pretty good about customer service. But if you're the antsy type, like myself, you can reprogram the firmware on the tazer and remarry...and ensure you do the two sleep cycles....I have heard some strange stuff can happen if you don't do that.
LUKYDUK
LUKYDUK
Tim
North Texas
Took a while for them to respond, but they ultimately recommended returning for a new unit (after UNMARRYING, rebooting and two full sleep cycles).
LUKYDUK
LUKYDUK
Tim
North Texas
***Update***
Installed the replacement today and it appears to work perfectly. Must have been a defective unit and am now a very happy customer.
