Unplugging DRL lights?
ketelhut
Paul
Thousand Oaks, CA
2021 JLUR
Doing the fender chop. What's the trick to unplugging that connector? I've pulled the red tab.
jludave
The Isle of Long
IT Manager
nU7OuxIx
Chicago
2025 JLU Rubicon X, YJ, Impreza
There's a setting to disable DRL in the radio.
Terrymo
Terry
2023 JLURXR 3.6 ET
Pull the red tab back. Push down on the small black piece in the center while pushing the two halves together to release tension. Then pull the two halves apart.
ketelhut
ketelhut
Paul
Thousand Oaks, CA
2021 JLUR
I'm not a master mechanic, hell not even close to a journeyman mechanic, but I've unplugged electrical connection in cars before. Tried what you said & this thing just doesn't want to come undone. New light is in place & looks great. Sure would like to be able to plug it in.
Jbudz511
Josh
NJ
'21 JLU Sahara Altitude, '00 XJ Sport
Thanks for all the help. Got it unplugged. I think I was pushing down in the wrong place. Lights look good & they work.
Don't lie, you spit on that thang didn't you?
In all seriousness I've fought with many connectors before. If only they were all as easy as the ones for the doors 😂
