3" Cube lights (w/DRL)
jakmobile
Iowa
2023 Jeep Wrangler Sahara 4xE
Hi guys, I just recently purchased a new bumper for my 2023 4xe and looking for 3'" cube lights for it, DRL would be nice but not a necessity. I'm thinking flood lights since I'll be keeping the factory LED fogs. Open to suggestions. There are SO many on the market that I'm not sure what's worth buying and what isn't. Can you guys provide any suggestions for lights under $100? Links if you have them. Thanks!
SoCalDriver
San Diego, CA
23 JLURXR
Following
I’m looking for the same, want something that mounts on the bumper in the existing holes
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I run KC C3s, they're a over $100 a pair though.
I'd at least consider a driving beam if you are just doing one set, not sure you'll find a cube in that beam style.
SoCalDriver
San Diego, CA
23 JLURXR
I don’t care about the price, just looking for good looking compact LED lights that mount into the existing bumper (steel factory)
will those fit what I’m looking for?
thanks!
GATORB8
CLT NC
thanks!
OP was asking for cubes.
KC has a new flex series out that is setup for the fogs that has both a SAE rated fog and a spot beam. >$500 though.
GATORB8
CLT NC
jakmobile
Iowa
Worked on getting my new bumper installed most of today. Ended up getting 3" cubes but I think the bumper can fit bigger ones. Also have stock LED fogs and a 12" light bar.
Question, do the aux switches (OEM) have relays built into them?
GATORB8
CLT NC
Yes, relays built in.
jakmobile
Iowa
Good to know, so as long as I run the positive to a pig tail and ground it to the frame, I don't need the relay it came with? Also, noticed there is a yellow wire in the connection to the power switch that came with the lights. Do I need to do anything with that?
GATORB8
CLT NC
They have DRLs? Which ones did you get?
jakmobile
Iowa
Nope, no DRL's unfortunately.
GATORB8
CLT NC
The switch will have an in and an out. If it has a light, it may also have a ground.
Whatever wires run directly to the light should be all you need.
