mtbjeep
Good morning all. Last December (2022) I had a MC 2.5" True Dual Rate lift installed on my 2018 JLU Sahara. Along with the lift I installed 35" Maxxis RAZR AT tires on my stock wheels. Upon picking it up I noticed that it had a definite shimmy that turned into a full blown wobble with the right bump and right temperature (<35f). I took it back to the shop to troubleshoot and they did absolutely nothing to help me out. Really disappointing because they had been great until the check cleared. Rolling into spring, with the return of warm weather, the problem almost disappeared. Nonetheless I had it on my radar to establish a relationship with another shop, and address the issue when the weather started to turn cold again.
So this past November & December the new shop tore into the Jeep and did everything we could all collectively think of. Worn parts were replaced, everything was re-torqued, ball joints were replaced, ball joints were re-replaced with another brand, stabilizers were swapped, geometry correction brackets were installed & removed, tire pressure was played with and we aligned, re-aligned and checked the caster throughout. Nothing made the slightest bit of difference. During this process the shop Owner and lead tech had suggested changing the tires on multiple occasions; perhaps there was a defect in the tires causing the issue. I routinely pushed this suggestion aside as I had rotated the tires 3 times since the lift was installed and the problem never went away. The chance that all 5 tires had some unseen issue seemed impossible to me. Well, with 5 seconds left in the 4th quarter before we burned the Jeep to the ground, the tech again made his tire suggestion. Shortly thereafter, rolling on stock tires and rims from another Jeep, I headed to a stretch of road that had become known as Death Wobble Alley. Wouldn't you know it, not a single shimmy, wiggle or wobble.
I ask the collective brain here how is that possible? What could possibly be wrong with the tires that causes shimmy & wobble when they balance just fine and run smooth as silk?
I'm going to have to abandon these tires and spend a small fortune on new tires; but before I do I am beyond curious as to the why...
Thanks!
Thanks!
