Uconnect update error
OldGuyNewJeep
Don
CT
CT_LFC
CT_LFC
SC
Volvo XC90 / JLUR
Ok so here’s my software version. Surprised it says 2021 since it’s a 2019MY, unless it was previously updating just fine.
Jeep Wrangler JL Uconnect update error IMG_5395
OldGuyNewJeep
Don
CT
So the number you care about in that application version string is 39.6. You’re one update away from current, which is 40.1.
Spank
I totally agree, but I am struggling to find what else would be causing the issue.
Fire up the Dealer Mode menu and snap a pic of your Radio Part Information screen.
Slambonie
CA
2018 WRANGLER UNLIMITED
I’m having this same issue with update failing at 18% error code 20. I checked dealer mode and version is 39.6. Correct to assume I can manually update via USB stick?
my car has also been getting traction control error lights on the dash and check engine light showing up, other weird dash lights turning on then being gone next time it’s driven. Is this all caused by the out of date software?
OldGuyNewJeep
Don
CT
Yes, you can easily upgrade from 39.6 to 40.1 via USB.
No, the idiot lights are not related to UConnect. You either have dying batteries or bad canbus connector. Both topics are well covered on the forum.
swampflyer
rick
florida
retired
I wonder if there’s gonna be any updates after 40.1?
Silly Seahorse
Terri
Maryland
2019 Jeep Wrangler Unlimited Sahara - Bikini
Check to see which version you're running now. If it's new enough, you can download the update onto a USB stick and force the update. If it's too old, you risk "bricking" your system by updating all the way to the latest version. Here's a link to a thread with details on how to check your current version, what versions are to old, and how to download/install the update.
https://www.jlwranglerforums.com/forum/threads/new-update-for-8-4-uconnect-radio.107222/page-37
Thanks for the info. It downloaded in 22 minutes and seems to be working fine. No messages over the weekend. Saved me a minimum of $180.00 and maybe much more. The dealer warned me that it might be a head unit issue instead of a download issue. I'm always skeptical of service departments that prewarn of a catastrophic failure.
