Turbo upgrade
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
If you do decide to go the route of an aftermarket turbo, I would strongly advise against anything with real performance gains. The bottom end on these engines aren’t strong enough for it.
whitechocolate
Fl
2021 JL 80th Edition
Are you idling your Jeep to cool it off before shutting down? My guess is your shutting it down hot and the oil is cooking inside the turbo.
Your manual has recommendations for when you should idle and cool down before shutting off the engine. Every time I go to shut down I put my heat on full blast and wait until my engine oil temp falls below 200° F before I shut down. Excessive? Most likely, but this engine runs hot and heat soaking your turbo with hot oil will cause issues sooner or later.
Edit: Page from my 2022 Gladiator below.
That's interesting, thanks for sharing. In the summer garages become wicked hot and pulling the Jeeps into an already hot garage without additional cooling probably adds more stress. Interested to know how much heat becomes trapped at that point under the hood for all engines Jeep puts out. Does the 2. turbo would have something similar in it's manual?
