Trim screw
Ctaylor1432
St. Cloud, FL
2019 Jeep Wrangler MOAB
I lost the small screw that holds the rear passenger side trim piece on a JLU. it’s between the woofer and the passenger side rear door. Any help would be appreciated. Where to order one?
TrailTorque
JLU
You’ve got 2 options really, maybe really only 1?
Possible Option 1: search the web for the IPB.
Option 2: Contact any dealerships part Dept and have them search the IPB and order for you.
Hope this helps a little man. When you do find the P/N please post up here as it may help someone else out in the future.
liquids
Detroit
2018 JLU Sport S, 1968 CJ5
Another option: Find another existing trim bolt on your Jeep that will thread into that hole. Take that bolt to your friendly neighborhood hardware store and find a replacement that's acceptable. Screw it in and color the head with a black magic marker.
I believe it's this screw. I think it's the same screw as the rollbar trim. The Mopar spec for the rollbar trim says this:
Mopar Part No.:6101946 and calls it a 4.2x20 mm self tapping screw. However, my measurement of the major diameter suggests it's closer to 5mm. Pull one of your rollbar trim screws and measure it. I think you'll find it's the correct screw. If not, hit the autoparts store for their "emergency" parts rack or just put a #10 sheetmetal screw in there. It's a "tinnerman" nut (formed sheetmetal nut) and has a bit of flexibility.
Jeep Wrangler JL Trim screw 20210214_180729
Jeep Wrangler JL Trim screw 20210214_180709
Jeep Wrangler JL Trim screw 20210214_180924
neil
neil
Dallas, TX
20 JLUR, 21 JLUR and others
I bet the part number is available at our forum sponsor.... allmoparparts.com
or eBay.
Very nice calipers btw.
All else fails, go to the hardware store and get a #10 panhead phillips sheetmetal screw, use a black marker to darken the head and be done.
If you are ok with a phillips head instead of the torx head, you can buy black #10 x 1" trim screws in the Dorman OEM replacement rack at O'Reilley or similar auto store. Dorman 961-2010 . I just replaced that very screw with the Dorman part.
