Obi Wan
- Obi
- May 14, 2022
- Tatooine, Outer Rim
- Website
- starwars.fandom.com
- 2023 JLU SPORT S 2.0, 2004 TJ SPORT 5.3LS
- Occupation
- Jedi Knight
I have a Tazer. If you watch the trans temp when engaging Cooldown Mode, you will see the temp immediately go to 229°F. This is a set value and does not represent the actual trans temp.Yes I have a tazer put I not sure what this part means
Cooldown Mode: Press ▷ + CRUISE CANCEL to
turn the engine fans on High. Press again to turn them off.
NOTE: When the engine is off, the fans will turn off
automatically if the battery drops to 11V.
NOTE: The transmission temperature will read as 229F
while this mode is being used with the engine running.
NOTE: Only works with the engine OFF on manual Jeeps
Is it reading the temp or is the 229F a set number wile in cool down mode
