mitchell8621
Trying to figure out where to start, My 2018 2.0 JLU has started to run very hot, but only at drive thru or extended idles of 2-4 minutes. The Jeep constantly stays at 220 or under during all normal operation, but if I pull into a drive thru, it will jump up to the mid 240-255 range, causing the heat warning to come on the dash. The fan does kick on, and it will hover around the spot without maxing out the temp on the dash. Once I clear the idle position, the car's heat will settle down within a few miles of driving back to normal and the warning light goes away. Thinking of starting with the thermostat if there is not a better place to start. No fluid leaks in my garage, I am in Florida, this started happening a month back when we were in the upper 80's but has never done this in the 5 years I have owned the vehicle.
