robertsj22
I’m getting bigger rims and tires. Is it easy to transfer sensors from the factory wheels? Or just better off to buy new ones. Where should I look to purchase them. These are on a 18 jlu sport
@robertsj22I’m getting bigger rims and tires. Is it easy to transfer sensors from the factory wheels? Or just better off to buy new ones. Where should I look to purchase them. These are on a 18 jlu sport
You need a programmer like a Tazer, or a security gateway bypass cable with an OBD2 scanner/reader and the JSCAN app. There are a few other options that work with the JL, but these 2 are the most popular.Does anyone know how to change the settings. My tires have 30psi in them and the low psi alert always comes up. Can I change it to allow for the 30psi setting?
There are no settings in the sensors themselves. It’s the vehicle’s WCM that’s programmed to read what the sensors send and alert when the pressures are lower than what the vehicle is programmed for.Why can’t tpms be set to a lower threshold prior to installing? Doesn’t the sensors just pass on information to the wireless control module ?
