Tpms sensor misbehaving
jameslavis
toronto, ontario
Jeep JL Unlimited Sport S
Got my wheels and rims switched. Front driver wheel didn’t read and 10k later it did.
All read for an hour then the other 3 went out. 10k later they came back. Was fine for a day, front passenger went out. Came back 10k later
When they go out the system says to service tire pressure system
Any ideas? Thought the system refreshes itself.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Were they new TPMS sensors or did you use the ones the JL came with, lots have had trouble and it seems to come from aftermarket ones along with the wheels used
jameslavis
toronto, ontario
Removed from stock. They are the same ones that came with the Jeep. Not sure if the dealer needs to reset them. Kind of lost here.
WranglerMan
Will
Greenfield Indiana
There is no reset, the TPMS sensors on the JL are self learning and should be picked up by the modules within a mile or so of driving.
What type of wheels do you have, some have reported with a large offset that it pushes the sensors out to far from the module to read 100% also you can go to any discount tire and they can use a handheld to read the sensors on each wheel to ensure they are working correctly
Roadglide
Southwest, FL
2019 Rubicon
The dealer can reprogram the sensors with his scan tool. Dealer is the only one that has the software at this point to do it. I had to do it and it was simple and free.
WranglerMan
Will
Greenfield Indiana
I thought the only reprogram option was to have the limits adjusted
Roadglide
Southwest, FL
2019 Rubicon
They plug their scan tool under your dash and then go around to each tire with the scanner. It worked on mine and I have new wheels and 35"'s. Try it. Anybody that drives around with that idiot light on their dash everyday must be a real piece of work. Why not go back to a old TJ or YJ then. :)
WranglerMan
Will
Greenfield Indiana
I did not know that and yes that idiot light or warning messages would drive me nuts ...
If I had to use the Jeep Dealer here to do that it would take them two days and they would still screw it up..
jameslavis
toronto, ontario
Have the cooper at3 with original sensors moved over. Seems like every day one goes out and comes back on the next day. Endless cycle.
Will take it back to my tire guy to look at. Any tips from the Jeep pros on what the likely issue is?
Steveo
Sitting on the lap of someone you love
'18 Wrangler JLUR, '23 F150 Rattler
Retired Code Monkey
I have 37s and did some froading today. When we got back on the pavement one of my sensors was showing 45 lbs. on the dash. I checked it with a gauge and it read 35 lbs. (what I'd inflated it to). At some point on the freeway it went back to 35 lbs. on the dash.
jameslavis
toronto, ontario
Mine just go to the —
Then reshow psi. It’s a pain
