Tire Suggestions
JEEPCINEMA
Cinema
2024 2-Door Sport
Hello All,
Any suggestions on off road tires that are also good on pavement? I guess not as loud on the road. Also, not super heavy.
I don’t do any heavy off roading. Light trails and fire roads. I would like to get to my long distance camp sights with some quiet(er) tires, but still good off road.
Thank you.
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
This one ☝.
JEEPCINEMA
Cinema
2024 2-Door Sport
Terrific tire, light for size, 3 peak, Toyo AT3 . The lightest 3 peak found in 35/12.50 at 59 lbs. very pleased with them. Chosen over MT BB because they were ~10 lbs heavier. (KO2 ~5 lbs)
I’ve noticed a lot of praise for the Toyo. Thank you.
rmeJeep
Dallas
2023 JLU Sahara, 2018 JKU Sport S
Another vote for Toyo AT3. I have 10k on mine. Smooth and quiet on road and do well on trails and rocks (I've only tried easy to medium so far).
JEEPCINEMA
Cinema
2024 2-Door Sport
Are these E load?
LARSONEM
Eric
Eaton Rapids, MI
2022 Jeep Wrangler Rubicon XR Unlimited, 2021 Jeep Willys 2 door
I kind of like the BF Goodrich KO2 all terrain tires. Had them on my 1997 TJ, 2012 JK in 315/70 load range E and 2022 JL in 315/70 load range C. I personally don’t think they are noisy and offer ample off road traction for the mild off roading I do. I hated the BFG Mud Terrains that were on my 2021 Willys and since I bought it to use as a winter vehicle primarily on street, I swapped them for 255/75 Michelin Defenders; quieter and better handling. A friend that off roads his 2018 JL with us runs the same tire in 295/70 loader range E size and they work well.
Traveller128
Robert
Oasis Idaho
2022 Willys 2 Door 6 speed
Volvo Master Technician
Swapped from 255/80R17 Falken AT3W's to 34x10.50 Toyo AT3 and couldn't be happier. They stick to everything and ride better.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Toyos on mine. Smooth at any speed.
Aonar
N.W. Iowa
2012 Rubi and Snazzy 2021 JLURD
Any suggestions on off road tires...I don’t do any heavy off roading.
-You can save weight by going with a "pizza cutter". There are multiple threads. It is what I did. These fit nicely inside the fenders. 35X10.5 Kenda Klevers
Jeep Wrangler JL Tire Suggestions 1767550023461-61
Here is one: https://www.jlwranglerforums.com/fo...cutters-aired-down-contact-patch-size.156057/
Another: https://www.jlwranglerforums.com/forum/threads/anyone-running-kenda-klever-r-t.151718/post-3141947
They are great Offroad. They got me up "The Wall" on Poughkeepsie Gulch when I had the correct line:
Seems you want offroad tires, but you say you don't do heavy off-roading. I went with the RT's (rough terrain) instead of the MT's (mud) or AT's (all terrain).
There will be a compromise no matter what you choose. You just need to figure out what is the MOST important to you.
-I do NOT care about road noise...it's a JP
-I wanted them to do well in MOST offroad situations. I HATE mud so no MT's for me
-I wanted them to be respectable in snow...did not want/need 3-peak snow tires. I live in NW Iowa and get a bit of snow and ice. I am still happy with these.
-Wanted good sidewalls :) I have sliced one before.
Jeep Wrangler JL Tire Suggestions 1767550850004-64
You just need to decide your most important Wants & Needs! GL with your search.
Aonar
N.W. Iowa
Deleted User 38384
Hello All,
Thank you.
That depends. What size tire are you looking for?
JEEPCINEMA
Cinema
2024 2-Door Sport
I do like the pizza cutters. They seem to drive a little better than the wide tires.
