Tire size-internal debate
Upnover
Michigan
None
The age old story…what size of tire.
I am debating between 37 and 39 KOs. My struggle is do I go with 39s. Haven’t ran that size before but I have always wanted to do it.
Or do I go with the tried and true 37s, which I have ran all the time. I like the BFGs don’t plan to go with any other tire brand.
I have an 24 XR with the newer axles. Know plenty of folks who run larger tires on them. I know of the risks blah blah bigger axles.
I can always do that later but I am not sure if I would regret just sticking to 37s.
DD 37s is just fine. Not sure 39s.
What says everyone?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I'd expect the 39s to be equivalent to 37 or maybe 38 Nittos. My 37" KO2s were definitely on the small side.
Anything over 37" always comes with a big price jump, but it'd be really hard for me to swallow the extra $1500 for the 2" jump on the KO2s.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
GATORB8
CLT NC
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
What says everyone?
Forgetting to mention what size lift you have…
GATORB8
CLT NC
mrtm1970
Marshall
Orlando, FL
Mechanical Engineer
I'll see if I can find my real world measurements of the 37" KO2, IIRC they are not the advertised size (36.5") mounted.
This is 37" KO2 and 38" TG:
Dang the 37s look tiny compared to the 38s 😲
Jmazz
2018 JL Sport
Once mounted, they will sag a bit under load as well depending on tire pressure. I assume you already Jscan in tire size to correct the speedo and have a 4.10 or 4.56 axle gear? Otherwise you trade cool looks for driveability
azwjowner
Phoenix
Very much so in real life. The TG isn't under load in this pic like the KO2 is (and the KO2s are worn), but:
That is a very misleading photo because the tire closer to the camera lens is going to look larger, plus all tires lose at least an inch under load on a vehicle.
GATORB8
CLT NC
This one was more misleading, lol. They are substantially bigger in person.
Jeep Wrangler JL Tire size-internal debate IMG_9842 (2)
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
39" KO2s are ungodly expensive. Depending on where you buy, they can be $900 to $1000 per tire. At least that was the quotes I was given locally. So, that means about $1500 more for a set of tires. Are BFGs worth that to you?
GATORB8
CLT NC
Not quite that much here, but the delta is correct, 85% increase in tire cost.
Jeep Wrangler JL Tire size-internal debate 1752160822454-of
Jeep Wrangler JL Tire size-internal debate 1752160845605-x9
Beachbumb
Destin
2024 Rubicon XR
If you want AT’s, look at the new Toyo’s. The 37’s are more true to size. I wouldn’t plant a flag on BFG’s. Tires are huge investment these days..
Glamisfan
SoCal, 30 minutes from Glamis
2020 Sting-Gray JLUR
I just retired 39” BFG Mud Terrains after 54,000 miles and 5 tire rotations. I was super happy with them. This is on a 2.0 JLUR with the stock 4:10’s. They were $420 at Costco in 2021. I would not pay the $700 that they want now.
I just put the new Nitto 38x11.50x17 Ridge Grapplers on it and find that the pizza cutters ride smoother.
