Tire Fill Alert on 2024
Melchior
Mel
Los Angeles
Toyota GR Supra
Those of you that have ‘24s with the newer Uconnect system…how do you use the Tire Fill Alert feature? I only see a “check” and “uncheck” option for Tire Fill Alert under Driver Assistance. Where do I find the ability to adjust desired measurements?
Melchior
Mel
Los Angeles
Toyota GR Supra
Ok…just figured it out. It’s buried deeper in the menu settings. Just in case anyone else runs into this issue, you have to have the vehicle Running.
1st go to “Settings”
2nd go to “Safery & Driver Assistance”
3rd Scroll down to “Tire Fill Assist” and click the circle to turn it on.
Then,
1st go to “Apps” icon (on far left permanent icons way at the bottom)
2nd scroll down to “Vehicle”
3rd Tap “Select. Tire Fill Alert” and from here you can create/adjust several custom preset settings. Mind you, this icon will be greyed out everytime you start the jeep. I believe you have to repeat the entire process I listed above.
