Time to replace track bar bushing?
tanner
Tanner
Scottsdale, AZ
2019 JLUR 2.0L
Just started getting a little shimmy in the steering after hitting a bump in the road. I suppose it's the first signs of something being off in the front suspension. I went through and torqued everything. None of the bolts/nuts moved.
Next I started it up and had a helper bump the steering back and forth. I noticed a fair amount of play with the track bar at the frame side mount. Could someone take a look at this video and suggest if this looks like normal play in the bushing or if it's excessive? https://photos.app.goo.gl/QbnvRm28ocgLbbX76
UPDATE:
Failed to mention initially that this is an aftermarket EVO Mfg track bar. It has been on the Jeep just over a year (10-15k miles).
XJfanatic
El Paso, Tx
2020 JLU, 2020 JT, 2000 TJ
The frame side mount bushing is actually a ball joint / flex joint. My guess is that if it’s shimmying it’s probably time to swap out the bar.
I just watched the video. That thing is shot!
Sorbs
Brian & Sunny
Colorado Springs
21' Ram TRX, 20' Gladiator LE
Try this:
