Updated front trackbar with stiffer bushings coming to help cure STEERING issues 68394087AA
  1. californiajeeping
    californiajeeping Well-Known Member
    Vehicle(s):
    JLUR
    Feb 1, 2019
    1,127
    Liked:
    662
    #1 Mar 10, 2019
    Note: The new and improved track bar has been available as of late February 2019. So it can be ordered now. Also, there is a reference to a 2 door in the Star case. It is referring to a 2 door TSB. This Star case applies to both a 2 and 4 door JL.
    Star Case Number S1819000003 about steering problems was just updated on Feb 26, 2019. See screen grabs of the part about the new JL track bar with stiffer bushings and the new toe info below. The old track bar number was 68317849AA. The new track bar part number is 68394087AA.
    And here is the toe spec info -
    Here are just a few of the steering related threads.
    https://www.jlwranglerforums.com/fo...ering-feels-like-it-has-play-and-drifts.3691/ (over 3,000 posts)
    https://www.jlwranglerforums.com/forum/threads/steering-wheel-wobble.16577/
    https://www.jlwranglerforums.com/fo...ring-is-good-tight-no-wander-no-wobble.21691/
    Helpful links
    Original version of this Star case from Oct 2018 - https://www.jlwranglerforums.com/fo...has-play-and-drifts.3691/page-142#post-426243
    JL Torque Specs - https://www.jlwranglerforums.com/fo...rangler-jl-steering-related-components.18510/
    JL Toe Specs - https://www.jlwranglerforums.com/fo...heel-alignment-specs-toe-caster-camber.17832/
    FULL ISSUE BULLETIN BELOW:
    PDF attached:
    Aceman, Old_Greggg, poolman and 5 others like this.
  2. Hgrace
    Hgrace Well-Known Member
    First Name:
    Harry
    Vehicle(s):
    2019 JUL Sport S, Fleetwood 33 Terra SE. Lincoln MKC. Chevy 2500 HD
    Jul 8, 2018
    Southern California
    320
    Liked:
    231
    Well this looks promising for many. But will it become a National recall?
  3. NFRs2000NYC
    NFRs2000NYC Well-Known Member
    First Name:
    Vehicle(s):
    2014 Jeep Wrangler Unlimited Rubicon
    Nov 28, 2017
    NYC/NJ
    501
    Liked:
    413
    The problem is the trackbar is hollow and weak, as is the draglink, and can't handle the job, especially with larger tires. Replace those this solid quality parts and you'll be golden. Dont waste your money on stabilizers.
    rayzjeep and Jschmadeke like this.
  4. fat_head
    fat_head Well-Known Member
    Vehicle(s):
    2018 JLU
    Mar 28, 2018
    544
    Liked:
    874
    Any chance you can post all the pages of the STAR case? All I see is one page.
  5. SpringsJL
    SpringsJL Well-Known Member
    First Name:
    Cage
    Vehicle(s):
    18 JLU
    Aug 2, 2018
    149
    Liked:
    162
    Will aftermarket still be a better option? Don’t want to wait around for this to recall
  6. OP
    californiajeeping
    Vehicle(s):
    JLUR
    Feb 1, 2019
    1,127
    Liked:
    662
    #6 Mar 10, 2019
    If the dealer feels the new track bar will fix the problem, then it would be covered under warranty.
    About aftermarket parts, I spoke with a few different dealers and asked them how it would affect my warranty if I put on aftermarket parts, such as a beefier track bar, drag link, etc. All of them said depends - for example, if your engine or A/C has a problem, and you installed a drag link, no problem. If I installed an aftermarket track bar or drag link and the problem was steering box related, they would either refuse to look at it or charge me for the steering box and labor to install it since the steering parts can directly affect each other. There are several posts throughout the forums with others who stated the same thing.
    For example, someone posted that they put on an aftermarket steering stabilizer and the dealer refused to address the steering problems. I quoted the The Magnuson-Moss Warranty Act and they gave an example - if a bad OEM steering stabilizer can cause problems and make a steering box go bad, so could an aftermarket steering stabilizer. Sure, you could take them to court to proceed, but that is expensive and once you mention lawyer or court (which they like because that is an instant way they can kick the can to someone else and get you off their backs), they kick it up to FCA corporate and then it takes forever to go to the next step. Or you could drive 3 hours to a dealer who is more aftermarket parts friendly, unless someone lucked out and their nearest dealer is aftermarket parts friendly. And of course, you could always put the OEM part back on before you bring it to the dealer, but what a pain. Here is an example of dust voiding warranty.
    Roky likes this.
  7. fat_head
    Vehicle(s):
    2018 JLU
    Mar 28, 2018
    544
    Liked:
    874
    I have my eye, and in some cases, have already purchased some aftermarket suspension parts that I have yet to install because of the wandering steering problem. I want them to sort it out ALL STOCK before I start spending money replacing/upgrading parts. The dealer I'm working looks for any and every opportunity to get out from under warranty work.
    DanW and californiajeeping like this.
  8. OP
    californiajeeping
    Vehicle(s):
    JLUR
    Feb 1, 2019
    1,127
    Liked:
    662
    I sent it to Jay / forum administrator to post in the TSB, Issues, Recall thread earlier today. It should be uploaded in the next day or so. It is exactly the same as the original star case S1819000003 in the TSB, Issues, Recall thread except for the part that I posted in this thread and the date is Feb 26, 2019, instead of October 10, 2018. They updated the same star case instead of creating a new one. Bad idea since dealers will say "yeah, I know about that one". Yes, but they won't realize it changed since they don't get proactively notified plus the changes aren't on the first page.
    Birchrun, Euro JEEP and fat_head like this.
  9. OP
    californiajeeping
    Vehicle(s):
    JLUR
    Feb 1, 2019
    1,127
    Liked:
    662
    Have you tried changing the toe-in to 1/8" to solve the wandering problem? Every dealer seems to say it is in spec and won't fine tune it - but now you can print Star case S1819000003, highlight the part about the new toe-in recommendations, and wave it in their face.
    Roky likes this.
  10. Mattyp1214
    Mattyp1214 Well-Known Member
    First Name:
    Vehicle(s):
    Black 2018 JLUR
    Oct 27, 2017
    771
    Liked:
    537
    I didnt want to wait and went ahead and got yeti HD. Thing is a beast. I'm sure new trackbar still won't even come close to this thing.
    SteadyC and xeon like this.
  11. OP
    californiajeeping
    Vehicle(s):
    JLUR
    Feb 1, 2019
    1,127
    Liked:
    662
    Here is another thread supporting what you said about aftermarket parts and warranty - https://www.jlwranglerforums.com/fo...termarket-steering-components-warranty.24841/
  12. Mattyp1214
    First Name:
    Vehicle(s):
    Black 2018 JLUR
    Oct 27, 2017
    771
    Liked:
    537
    If you are having a lot of issues I'd let them try and fix it first. I did not have any issues other than bumps at high speed would throw my wheel off and handling became pretty rough. Put on track bar to help.
    For the steering issues I'd start with the steering box replacement and stabilizer together. Seems to be the ticket for a lot of folks if it is really loose.
    californiajeeping likes this.
  13. OP
    californiajeeping
    Vehicle(s):
    JLUR
    Feb 1, 2019
    1,127
    Liked:
    662
    Makes sense, and someone in a post a few days ago said their dealer via FCA indicated the bad date code steering stabilizers were causing steering boxes damage.
  14. Rdmitch
    Rdmitch Well-Known Member
    First Name:
    Ross
    Vehicle(s):
    2020 JLUR, ford transit 250, Chevy Equinox
    Jan 13, 2019
    Elyria, Ohio
    418
    Liked:
    344
    Occupation:
    Mechanical designer /contractor and musician
    new track bar and steering box should get you about 60% better
  15. OP
    californiajeeping
    Vehicle(s):
    JLUR
    Feb 1, 2019
    1,127
    Liked:
    662
    #15 Mar 11, 2019
    Also, there is a new and improved OEM Link Rod as of mid Feb 2019 - it connects to the pitman arm. The new OEM Mopar part number is 68258760AD.
Loading...
Share This Page
