The "hate" on Jeeps + Speed
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I know the Jeep is not a sports car, nor is it something that will win a rally race.
Aren't you the one that said:
So, yes a Jeep Wrangler *could* enter and win a rallycross.
If your main desire is to to go off road at high speeds then you really should avoid vehicles with a solid front axle. That's a SFA's Achilles' Heel.
As for the HP, the most HP I've driven for more than a quick zoom down the road is 301HP in a TRD Camry. A stock Jeep definitely won't have the same pick-up-and-go but so far it gives me the same thrills I had plus it can go offroad.
That's not even close to the 0-60 performance of a 392 Wrangler.
yokramer
Snark Incarnate
gek
Code Monkey
Like i mentioned before, a Mojave and a JLU are significantly different when it comes to suspension design and set up. A JLU without extensive mods won’t match a stock Mojave in the desert. And dirt roads don’t count as off-road.
Exactly, how many people say they went off road and when I ask where, they say I went to a dirt road. Then don't understand why I stare at them like this.
Jeep Wrangler JL The "hate" on Jeeps + Speed {filename}
Zandcwhite
Zach
Patterson, ca
2019 jlur
If you drive off trail you're an asshole and directly responsible for loss of access. Dirt roads are the only off road available period. The rubicon trail is a country road. A modified JLU can absolutely do what a stock Mojave can. We own both, and property in the desert. Both get driven there on a regular basis at speeds many on this forum won't even do on road. The suspensions aren't significantly different. The front suspension is identical which is why the control arms, sway links, etc are the same part numbers. The rear suspension on the JL is actually better setup for jumps at speed as the gladiator got the rams long as hell LCAs paired with super short uppers. The result is massive pinion dive and wheel hop, especially bad when cycling the suspension at speed. Put some ADS triple tube bypass shocks and hydraulic bump stops on the JLU and it would outperform a stock Mojave easily. Why the JLU would need long arms but the JT wouldn't is beyond me? And if we are considering a simple shock change more than mildly modified I must be on the wrong forum.
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
Have you even driven a Mojave in the desert, or just read hype on forums? It really isn't impressive at all compared to many other desert machines. It is better than a stock JLU, but not by that much. A stock JLU with an off the shelf set of King shocks could match it.
Atomic-Mouse
Northeast
some very sound advice at 12:58 and 13:31
Zandcwhite
Zach
Patterson, ca
2019 jlur
This is not a personal attack on you just on the concept.
If you think any Jeep Wrangler is fast (even just in a straight line) without a motor swap you haven’t driven a real sports car with any real power or anything from the true muscle car era. In comparison a Wrangler has no speed, no handling, and even worse aerodynamics. I think the saying that comes to mind, when someone talks about a Jeep like this, is polishing a turd.
I think you need to go test drive some modern sports cars and then hop back into your Jeep and feel the sad reality creep over you. Quickest best handling car I drove was a Dinan chipped twin turbo 911 putting out 450 horsepower. Hop out of that, change your chonies, and hop into a wrangler and it will feel like a riding lawn mower. Or don’t and continue to live in a happy, happy dream world.
Since you opened the can of worms, everything from the muscle car era was slow period. The '67 corvette L88 and '68 charger R/T 426 were the only 2 to break 5s 0-60 at 4.7 and 4.8s respectively. And yet the 392 does it in 4.5s on 35" all terrains? Yes there's been 60 years of advancement, but that's a Jeep not a sports car or muscle car. The model s plaid and lucid aire dream both do it in under 2s. Not to mention the OP literally said fast OFF ROAD. How's that 911 after a few miles of washboard road at freeway speed or a 3' jump at 100mph? No the Jeep won't hang with a Porsche on the track, but it would come a hell of a lot closer than the Porsche on the rubicon. No the Jeep isn't hanging with trophy trucks without major modifications, but freeway speed in the desert is easy and in my experience the JLU is better there than the 2dr Bronco and every bit as good as the 4dr stock for stock. Short arm, Honda civic style IFS is no better in the desert than a solid axle. People see trophy trucks, ultra4 cars, etc and think their stock Bronco has the same IFS. Go to a raptor, trx, or wide track conversion on a tundra, Silverado, etc and really good shocks and the JLU will fall behind mostly because of wheelbase.
shagles
Skylar
2020 JLU Sahara
adult toy engineer
I agree on driving off trail and i never suggested doing that when there are marked trails and that’s all that’s allowed to drive on. Even i know lots of the desert in the west is open public land and free to roam. Also, for the vast majority of the country, a dirt road and a trail aren’t the same thing. Calling the Rubicon a country road doesn’t make it one.
If all it took was a shock swap to get your JLU to perform like your Mojave, I’m happy for you. You’re the only one ive been able to find. From everything I’ve seen and built, having a longer wheelbase, even with just longer lower arms, smooths out the suspension travel when going fast cause the radius of the axle arc is much larger.
I agree a shock swap is a mild mod (i grew up on pirate4x4 lol), but for someone that doesn’t even own a jeep and hasn’t driven one off-road, triple bypass ADS shocks and hydro bumps are a decent step up from a mopar 100% bolt on kit in installation and spending. They’re not a straight bolt on like mono tubes and you know it.
shagles
Skylar
2020 JLU Sahara
adult toy engineer
Nope i haven’t. Haven’t read forum hype either. I’ve watched hours of videos and studied the suspension design, and i design suspensions for a living, so i understand what im looking at. If a simple set of shocks would make a JLU ride well at speed in the desert, why does basically everyone that wants to do that end up disappointed and give up? I have yet to see anyone be successful and happy with theirs in the desert, at speed.
Bleda2002
2021 JTR, 2021 Sahara 4xe
I don't need a jeep to be fast, but I greatly appreciate quick. Big ass tires and 0-60s in 6-7 seconds is way more fun than 0-60 measured with a sundial.
3TV
Southwest USA
So, I have owned two JT Mojaves and at the same time have owned a JLU with King shocks and I have decades of experience desert racing. And you haven't even driven a JT Mojave in the desert. I argue that the design of the Mojave is a little better than the design of the JLU, but that the implementation of that design falls short.
shagles
Skylar
2020 JLU Sahara
adult toy engineer
I’ll concede that you and @Zandcwhite’s experience with the platform outweighs my design experience and building and analysis of other platforms. Implementation can definitely make a design fall short. I still have a hard time understanding why you and @Zandcwhite have figured out how to make a JLU perform and no one else seems to. From everything that i have ever designed or built, the suspension layout of the JLU shouldn’t work well at speed without some decent changes. Maybe there’s something in the actual build that makes it better that i haven’t seen, or maybe im comparing it to a built long travel full size pickup and no one else is. That would make a miscommunication of scale make sense.
Terrymo
Terry
2023 JLURXR 3.6 ET
My comment was, relative to what’s out there, a Jeep isn’t fast, and in my opinion, isn’t a good choice as a starting point to go fast. Driving a vehicle “fast“ for the conditions doesn’t make it truly fast in my mind. We can both pick scenarios where a vehicle isn’t designed to be but that doesn’t change what I interpret fast to be. The other scenarios in your can of worms list don’t seem relevant to my definition of a fast vehicle. But on that we will disagree it seems.
