TAZER -- shift points and adding bigger tires?
NoDegree0311
Long Island, NY
2021 Wrangler Unlimited Sport Altitude
Hey everyone. Looking for knowledge from people who have the tazer in their Jeep. I have a 21 sport altitude with 3.5” lift and 37s on stock 3.45 gears (for now). Obviously my shift points are a lot higher from the tires and the vehicle won’t go into 7th or 8th gear on its own anymore so i bought a tazer to let my jeeps computer know it has 37s and could adjust its timing accordingly. After install and setting it up, i noticed at lower speeds below 50 my jeep would shift easy and feel good like it did when it was stock. But at highway speeds she still doesn’t like to go past 6th gear on her own. So i guess my question is those who have the tazer jl what’s your experience with shift points and adding bigger tires on there? Will my jeep shift like a stock wrangler if i have the tazer PLUS a regear? Or if i have a regear do i really need the tazer?
Jeep Wrangler JL TAZER -- shift points and adding bigger tires? IMG_2258
Bill_BCNtoNY
NY
Ocean Blue JLU Sahara 3.6
Advisor to Boutique Consulting Firms and Solo Practitioners
I have a tazer and had slightly bigger tires (went from stock Sahara to stock Rubicon sizes) before regearing. I'm a slow driver so I went to 4:56. The shift points will not be back to normal just with the Tazer, you need both that and the regear to make it work.
At the end of the day, the Tazer will fix the software, but your hardware (the gears) are unchanged and are just not up to the task of turning your 37s. I'd also argue that the stock gears were just selected to meet MPG targets, not functionality... but that;s a topic for another day!
yokramer
Snark Incarnate
Yup 3.45s on 37s will do exactly what you are describing. If you had 4.10s it would be a stretch to keep them but yea you need a regear bad.
Bill_BCNtoNY
NY
Also, I see you're in Long Island - do yourself a favor and pay a visit to Evan at his shop.
He did my gears and he's a true expert in building Jeeps.
Bill_BCNtoNY
NY
Yup - he did mine and he is a true expert in this.
Jeep Wrangler JL TAZER -- shift points and adding bigger tires? 1707406581238
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
You'll need something to tell the computer the new gear size. Tazer will do that although there are other options.
Carolina Jeeper
Rollie
North Carolina
2019 Mojito! Jeep Wrangler Unlimited Rubicon
Electronics Technician at R. J. Reynolds
I switched to 35" tires on my 4.10 geared Rubicon. It would almost never go into 8th gear unless on the highway. I used a Tazer to calibrate the tire size which corrected the speedometer. It shifts into 8th gear very close to the same as before the tire size change.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
lol regear your shit
rohdawg
Long Island, New York
Merchant Marine
emarrero
Ely
Downstate NY
2021 JLUR, 2020 Cherokee Trailhawk
i write code
Same here. 35's (34.6), 4.10, set the size with Tazer, finds 8th all the time. Not sure if a regear would be even nicer but I think I'm good for now.
Muskoka Minute
Bart
Muskoka Canada
2019 JL Rubicon
I’m just in the process of doing the same thing.
Good to know. Thanks
How did you MPG change?
Not that it’s going to stop me but was curious.
cheers
Carolina Jeeper
Rollie
North Carolina
cheers
My mpg dropped to about 16 mpg from about 18. These tires are Mickey thompson Baha Boss mud terrain E rated tires. Also, I'm running 26 PSI to get full tread contact.
If your tire isn't as aggressive, then maybe you will not lose so much mpg as I have. And of course this depends on if you decide to run reduced tire air pressure like I am.
