Tazer Mini - Swaybar Help & Shortcut Key Programming?
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
I have the newest software on my Tazer in a new 2022 JLUR. The swaybar keeps connecting at speeds over 18mph and under 30mph even in 4Hi. Sometimes it stays disconnected like it should, but sometimes it doesnt. Seems to work more in 2wd.
i read somewhere you can button map the disconnect so that when you do disconnect it stays off at any speed. I know you can disconnect and then go to programming and turn off the sensor, but that is a pain.
anyone map a button to do this? If so, how? Or is there a way to get the programming the tazer has to be more reliable? I have already rebooted twice, including the sleep mode process.
DavidArmen
Los Angeles, CA
2021 JLUR
Interesting, the limit should have automatically increased to 30mph with the tazer connected..
While in the audio section on your EVIC, you press and hold the right arrow and then you press whichever button you want to create the shortcut on (SET+, SET-, RES) and you keep pressing it until you see the shortcut that you need and then you let go of the buttons. Now any time you press that shortcut button, without pressing any other button on the left, that shortcut will activate. For example I have set SwayKill on the RES button. So any time I press the RES button, when the cruise control is off, the sway bar disconnects and stays disconnected at any speed until I either press RES again or I press the sway bar button.
My SET- is set to TurnAssist and SET+ set to Dark Mode.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
when you mean SwayKill, do you mean the option that turns the sensor off? wouldn’t that mean you have to disconnect first and then hit that button?
DavidArmen
Los Angeles, CA
2021 JLUR
No sir, SwayKill is just the name of the shortcut that disconnects the Sway Bar and leaves it disconnected until you either push the shortcut again, or you push the sway bar button.
The tazer JL instruction manual, although fairly outdated now as it was made when 11.2.8 was released and we are now on 11.3.4, actually has very clear instructions on how to achieve shortcuts and what each individual function does.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
All set thanks for the help!
AC87
Arthur
Surrey, British Columbia, Canada
2021 Wrangler Rubicon
Service Technician
Thank you so much for this quick write up, I followed your instructions and it works 100%. This feature is so good. Cheers
