Tap/Tick
Rockwall
2016 JK Willy’s, 2021 JL Sahara Diesel
Is the inconsistent tap normal for anyone else? Picked up Saturday so still under 100 miles.
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
People have found that random tap sound is a broken exhaust bracket. On the up pipe IIRC. If you search around for variations of what I said you'll find some pics.
Rockwall
Thanks. Those were with higher miles, but I need to look at the bracket. It went away…so thinking it’s something else. I did notice from search this is what you’re referring to: Diesel Tap - Alternator/Weld
diezselsmk
JLURD
sounded like the hydraulic lifters. mine will do this on a cold start for few seconds until they are under full pressure. its normal for a diesel and is more common when oil is new due to viscosity. mine has no leaks and does not burn any either for reference.
Rockwall
Ok thanks! I think I’m getting flashbacks from my 3.6 JK where a tap lead to replacing lifters and rockers. Appreciate the feedback.
