Tailgate Table
ttsquirrel
Cen CA
2018 Wrangler JLU
This is the Frontrunner JK table. Had to drill mounting holes in for JL tailgate and had to search for spacers and longer bolts. I used extra washers to make spacers the proper length. It works great and one of the least expensive tables with a slide out.
I really like that there are no holes in table, I can use with or without wood slider. Did I mention it’s cheap compared to some other tables?
Jeep Wrangler JL Tailgate Table EA8DE021-9368-4C77-9ADD-9F43B993AD88
ttsquirrel
Cen CA
2018 Wrangler JLU
You need to finish the wood.
After I finished with the polyurethane, I wished I would have put decal or design on wood before doing the sealing. I’ll just put stickers on now.
Jeep Wrangler JL Tailgate Table 19570E55-6A3D-414D-AF53-9CBC4939F5BF
jeepixel
Al
TX
WBGO View, 2019 2d Wrangler Rubicon
Looks good, nice job. Does it feel solid?
ttsquirrel
Cen CA
2018 Wrangler JLU
Here are the spacers, washers, and bolts I bought.
I made a template with the box it was shipped in.
Used a laser to line up top two holes, then used the template to get bottom two holes drilled.
If you do this table on your JL, just remember that you need to have the table low enough when it is folded down for the wood to be able to pull out under tailgate handle, yet high enough so that when you fold up the table and close the tailgate, it won’t interfere with seal or carpet.
[GALLERY=][/GALLERY]
Jeep Wrangler JL Tailgate Table F19D326D-B3A6-4408-90FC-BBFF73E79058
Jeep Wrangler JL Tailgate Table B5CE2523-F9F7-4DC7-93D2-06E89DAF534A
ttsquirrel
Cen CA
2018 Wrangler JLU
It feels very solid. When I received it in the mail and when I took it out of the box, I was not expecting it to weigh as much as it does.
One other thing about this table versus one where you won’t use OEM plastic tailgate grill, the OEM grill has filter on it for the rear vents in the tailgate. Another table replaces plastic grill with aluminum plate. I didn’t want that. Don’t know if vent filter is used with aluminum plate. Besides that table is more than double the price.
I’m very happy with the Frontrunner.
Here’s cardboard template, too.
TTS
Jeep Wrangler JL Tailgate Table E7E8A41E-548F-4A77-AD57-802C6B781428
HotKarlTheJL
Portland
Awesome, thank you!
Lou3.6
Lou
Eastern Washington State
75th Anniversary (2016) WK2 Trail Rated Laredo in Recon Green
Retired Navy (2004) Now, Loafer & Fly Fisher
The Frontrunner table is what I decided to purchase.seems like best bang for your buck.
I really wanted cutting board for extra space and hated having holes in my table.
Literally, less than half the price of comparable models like outback adventure.. I’m hoping quality is here with this less expensive table.
Let you see when I’m done with installation.
TTS
It's Jan 13 and I had been on the FrontRunner website NOT seeing this table -YET - for the JL, so I emailed them about it - will get back when/IF I get a response ! ? The one they show is only for JK !
edit; also on YouTube earlier I watched a 4 minute INSTALL video for the OUTBACK TRAILGATER Drop Down table via REBEL OFF ROAD ! This table is EASY install and I think is just as nice as the FRONTRUNNER Table. They both have slide outs, but the OUTBACKs is Bamboo - I think this is a better fit for cutting board use, if my memory serves me ! ? But in any case any of these slide out boards can be replaced !
If I knew how to "cut & paste" or whatever, to get the video HERE I would, but I'm a bit "slow" in those matters I'm afraid ! to "old skool" ha !
ttsquirrel
Cen CA
2018 Wrangler JLU
The outback is just as nice as the Frontrunner. However, the outback is $345! The Frontrunner JK table that I put on the JL is $130. I spent another 20 on shellac and parts. Still, that less than half. Frontrunner is a little slow on getting JL model out.
Also, I don’t plan to use the wood slide out as a true cutting board. I’ll cut on a plate.
Lou3.6
Lou
Just as Nice ? Have you access to SEE both somewhere ? Wish I could fine both, maybe if I make a few more calls to my local area and then to places in Missoula, I will be passing thru in July - Hopefully in my new JL by then ?
Yea the price diff. is quite "stunning," which leads me (too) to wonder about Quality of each ! I'm not overly concerned of that, rather I would like to SEE each before I buy - maybe I'll get to an "Expo" or Outdoor Sportsman's Show or . . . come Spring !
I want to be sure I am happy with my purchase 1st time 'round !
Springtail
Doc
Southern Iowa
2018 JLUR, 1977 FJ40, (RestoMod), 2018 Camaro SS Convertible, 2020 Tesla Model Y Performance
Co-Owner Springtail LLC
For those of you that had the desire to use a camp stove with the Springtail table but found that the front lip interfered with setting the stove up....we are working on an answer for that request and knocked out a prototype insert that can serve as a riser for a stove, a flat prep area and still allow items to be mounted to the MOLLE grid.
Actually, the initial prototype turned out pretty nice....fits well and bolts up easily.Should be plenty of room underneath for MOLLE straps or hardware to mount stuff on the outside grid. I think that this makes it the only table that you can mount things on the outside at the same time without one interfering with the other.
Sorry for the crappy pictures but it is minus 4 degrees outside and 35 mph winds. I'll get better pictures and some real life testing done soon.
Let me know your thoughts.
Doc
Jeep Wrangler JL Tailgate Table 1BA8B1C3-7580-4ADD-B84F-070B153F7F36_zpsns2wji5
Jeep Wrangler JL Tailgate Table 32FFB6FD-15C5-4971-BCAF-28813B9E1283_zpsbfjsxmqs
StingGrayRhino
Eliez
CA
Wrangler JL Sahara
I splurged and purchased this tailgate table / cutting board combo which is popular in many of the overlanding rigs I've seen (Tailgater) - https://ok4wd.com/camping-overland/outback-adventure-trailgater-table. Unfortunately some low-life scum stole it from my front porch before I had a chance to notice it had been delivered! Video here but the police don't expect this to go anywhere of course -
You should install another camera on that light poll to catch the license plates.
Springtail
Doc
Southern Iowa
God, I hate those people....they are the lowest of the low.
Doc
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
Doc
How is this going? I like that items can still be mounted to the grid.
lembowski
San Diego
2018 JLUR Sting Gray
Front runner told me that they are a month or so out from releasing the JL specific table. So if anyone doesn’t want to modify and can wait a little the option will be there.
jeepixel
Al
TX
Thank you for posting the update, as I am also interested in this lower cost option and hope a brave soul will order it and report back the findings.
