Switched speakers -Things gone
bipock
Newport, NC
2020 Sahara JLU
Switched my front 3.5 inch speakers today. Seem to be working fine. However I disconnected the battery before installing and reconnected it after the install. Now I don’t have my Offroad Pages, can’t change the temperature on the air conditioning, and have lost my back up camera.
Any suggestions?
jthoms1
Charlotte
2020 JLUR
My first answer would be like step one in troubleshooting a PC. When in doubt reboot. Did you disconnect the battery again to see if that resolves it?
bipock
Newport, NC
2020 Sahara JLU
I have. Nothing changed.
jthoms1
Charlotte
2020 JLUR
Any type of Tazer or other device attached? Check to ensure you didn't blow any fuses? That's a strange set of symptoms, such they don't seem like they could be linked, but who knows. Hopefully someone with a greater level of expertise will chime in.
bipock
Newport, NC
2020 Sahara JLU
What fuses? No Taser or anything of the sort.
Rvalas
Sean
Jarrell, TX
2021 Jeep JT Gladiator
it can take upto half a day for this to fix. mine did the same thing exactly, unplugged the battery to install the speakers and the offroad pages stopped for a time. next day on the way to work all was a ok.
bipock
Newport, NC
2020 Sahara JLU
Did your CM and back up camera disappear too?
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
When you dsiconnect the battery, turn the headlight switch on for about 10 minutes to fully drain any residual voltage from the system.
jludave
The Isle of Long
IT Manager
Any suggestions?
Let the vehicle sit for up to 24 hours. What you are experiencing is 100% normal. The radios in the JL are tightly integrated with the vehicle and need time to learn the vehicle and its functions after a battery disconnect. Patience is key here. Everything will come back after a while. No need to pull fuses or disconnect the battery again.
bipock
Newport, NC
2020 Sahara JLU
Thanks guys. We went out to eat some dinner tonight and when we got back to the Jeep, everything had come back to life but the off-road apps. We'll see what happens tomorrow.
Terpsmandan
Penn Yan
On my first disconnect it took about 24 hours for everything to come back.
bipock
Newport, NC
2020 Sahara JLU
Everything reset on the way to work this morning. All has returned to normalcy. Took about 12 hours.
