Switch Question
mcknight_14
Las Vegas, Nevada
2019 Jeep Wrangler Rubicon Unlimited, 2017 Jeep Grand Cherokee
United States Air Force
So I do not have the Mopar AUX switches installed in my 2019 Rubicon. I was wondering if anyone has done any custom aftermarket switch installation? I plan to make a relay box and install a switch panel inside but do not know the best place to mount the switch panel. I am trying to stay cheap on this I know there are Spods and other similar products but I am not trying to spend more than 200-250. I do like the Rough Country MLC-6 Multiple Light Controller but the relay box does not fit the 4-cylinder model. I am sure I can get it to fit somewhere without issue because I really like the switch panel, auto cut-off, and how the switch panel mounts. Are there any other options out there or any other custom ideas that any of you have done?
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Check out the youtube channel Ben Anton. He did a install video about adding custom switches to power aux lighting because he too does not have the factory mopar switch panel.
mcknight_14
mcknight_14
Las Vegas, Nevada
Thanks I will check that out.
Harrison
Harrison
Orange County
JLU Sport
Hey just following up on this thread I had the same question just curious what you ended up going with/mounting locations
-cheers
JaysJL
Jacob
Phoenix
2021 JLU Altitude
Not sure if this is still something someone is looking at but I just installed the rough country switches in my 4cyl and it works great
blnewt
New Mexico
Just ask @cosine he knows!
I just mounted my 4 switches here to the left lower panel, cost $10 (since I didn't have anything pulling more than 15 amps :)
Jeep Wrangler JL Switch Question IMG_0443
Jeep Wrangler JL Switch Question IMG_0444
Dewey7015
Cape cod
2020 JL 2 door, hardtop, 6 speed.
i'm trying to figure out a wireless FOB, to trigger the relay box, under the hood...and just have the FOB mounted somewhere...working on it...
Den_JL2DR
Den
Arizona
2020 SportS 2DR 6 Cyl Hardtop
Nice! Brad I appreciated your other topic post on wiring for the F57 tandem fuse; was very helpful to power an aux light relay next to battery.
Jeep Wrangler JL Switch Question Button_3
Those dash spaces seem easy to work, but are for nimble hands and patience, can't imagine
four switches, were they quick disconnects?
I pulled wire up into the engine raceway and through the manual trans firewall hole to one switch in that dash area and did solder but with wire pulled forward of dash, bit easier, and two screws behind, as the switch maker's solder needed rework.
Jeep Wrangler JL Switch Question Button_1
Jeep Wrangler JL Switch Question Button_2
blnewt
New Mexico
Nice job!
Yeah, I used insulated spade connectors on those switches to make the install easy. I used a 3/4" step drill for the holes and had to really press those switches in hard to get them to set, but they did :)
Dewey7015
Cape cod
Anyone put some OTRATTW switches here?
Jeep Wrangler JL Switch Question 20210113_073240
